Need help!! - Fender clearance Issues
Old Oct 30, 2009 | 07:24 PM
ws.MBZ.gang's Avatar
ws.MBZ.gang
Default Need help!! - Fender clearance Issues
right now i have tokico dspec's matched with the red swift springs. i have 18x10 +3 up front and im not that low. i want to put coils on and slam it but for some reason it seems as tho the studs holding in my fender lining is eatting away at my tires. what could i do?!? can i take off my fender lining?!?
Old Oct 31, 2009 | 07:35 AM
A little common sense is needed here.
Old Oct 31, 2009 | 08:57 AM
ws.MBZ.gang
and what would common sense bring you to do?
Old Oct 31, 2009 | 09:10 AM
terrasmak's Avatar
I would say 18x10 +25 , basically buy proper fitting wheels.
Old Nov 3, 2009 | 07:24 AM
Z04's Avatar
Z04
+1
Old Nov 3, 2009 | 07:57 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
You can try the following independently or in combination:
-Run more negative camber
-Trim the inner liner and push tabs up or remove the liner altogether
-Purchase a narrower/shorter tire to provide more of a stretch for more clearance
Justin100
Nov 25, 2021 06:26 AM
350z82
Oct 1, 2015 06:25 PM
Dymsi
Sep 29, 2015 11:32 AM
