Stop tech caliper issue
Old Nov 11, 2009 | 04:38 AM
six3mike's Avatar
six3mike
Default Stop tech caliper issue
So I took my front calipers off, ST40s, to repaint them. Well when I went to put them back on my right side caliper banjo bolt hole is stripped. Must of happend when they were initially installed. This is the first time I have removed them in almost four years. Anyways, anyone have any ideas or know if there are larger banjo bolts out there I can use? I'm about to just buy a new caliper but figured I'd try this first. Thanks.
Old Nov 11, 2009 | 07:22 AM
Zazz93's Avatar
Zazz93
Try a local machine shop, see if they are ok with repairing threads on brakes. I would imagine a good shop can repair the threads for about $60.
Old Nov 11, 2009 | 09:26 AM
StopTechErik's Avatar
StopTechErik
Vendor - Former Vendor
Just make sure that you realize the seal is created by the taper at the base of the bleed screw seating properly against the corresponding taper in the caliper. The threads are only there to allow the seal to be created between the machined surfaces.
Old Nov 11, 2009 | 05:53 PM
JETPILOT's Avatar
JETPILOT
Try buying a tap and chasing the threads.
Old Nov 12, 2009 | 05:06 AM
six3mike's Avatar
six3mike
Did the tap thing. No luck.
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
samansharif
Sep 25, 2015 12:31 PM
