Camber/toe kits
Old Oct 17, 2003 | 08:03 PM
uro279's Avatar
uro279
Default Camber/toe kits
Hey,
I have s-tune susp with sways and nismo wheels.
do you guys recommend the camber/toe kit?
asking because i don't want any issues with featheing down the line.
I am currently aligned now, but am still considering the above kit.
recs?
thanx
Old Oct 17, 2003 | 09:43 PM
dkmura's Avatar
dkmura
General & DIY Moderator
My track model uses the Eibach Pro-kit, Nismo swaybars and LSDuniques camber arms. There is no camber/toe 'kit'. The stock rear control arm uses an eccentric bolt to provide a small range of adjustment for camber and toe.
If you've had a full alignment and your car is within spec, I don't know why you'd worry about adding camber adjusters. If you're not running your car at the track, it's doubtful that tire feathering will be a big issue (unless you're at -2.5 degrees or more in the rear). For me, it was clear that a 1.2" drop in the rear gave me more rear camber than was optimum. Replacing the rear arms with LSDuniques nicely fabricated parts gave me a full range of camber adjustment and allowed toe to be set as well.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
