Planning to drop my Z, any suggestions?
Old Dec 11, 2009 | 09:31 PM
Cubhazl19's Avatar
Cubhazl19
Question Planning to drop my Z, any suggestions?
I want to drop my Z but I would like for the front to be a bit more dropped then the back so it can have that inclined look. I'm not sure where I should get the springs because most of them are even or the back is lower. Any suggestions, links maybe? And if I do drop it, will I need a camber kit???
This is my first post so please help me out on this one guys!
Thanks!
Old Dec 11, 2009 | 09:59 PM
zland's Avatar
zland
Sport Z Magazine
If I remember, NISMO springs are 3/4" & good drop amount. I went with 1" drop & had camber issue & scraping all the time = not worth it in the long run
Old Dec 11, 2009 | 10:15 PM
slimjim888's Avatar
slimjim888
3/4" drop with just springs, right? I wanted to drop too, but didn't want to spend too much on coilovers.. although I did hear that you need them if you don't want to have camber issues/wear out tires.. but that's if you go lower than an inch, right? so i'm assuming 3/4" is okay with just springs..
Old Dec 11, 2009 | 10:25 PM
Cubhazl19's Avatar
Cubhazl19
So, I should go with 3/4" in the front only? Or will that be 3/4" in the front and back? Remember guys, I would like the front to be lower, if possible. And will I need shocks as well??? To many things! Arghhh!!!
I think I can buy some decent springs on ebay, don't you guys think so???
Old Dec 11, 2009 | 10:30 PM
350ZTheStandard's Avatar
350ZTheStandard
OP Just go with Eibach springs if you can't afford now the $$$ for coiloverZ. Why are you trying to make the Z look like a cuate bomb with the aZZ in the air and the front end dragging on the asphalt.
Cubhazl19's Avatar
Cubhazl19
actually I think the set is always lower in the front, if I'm not mistaken.
Old Dec 11, 2009 | 10:32 PM
Cubhazl19's Avatar
Cubhazl19
well it was only an Idea 350zstandard, I still have all options open dude.
Old Dec 12, 2009 | 12:53 AM
aloh's Avatar
aloh
save your time and go for coilovers...
I used to have springs but I was never satisfied with the feel, look, and ride quality.
Old Dec 12, 2009 | 02:11 AM
Cut the front springs and make them shorter.
Old Dec 12, 2009 | 04:09 AM
diablox1's Avatar
diablox1
the Z is already a bit lower in the front. a nice even drop with eibach prokit (1" all around will keep your lower look in the front).
Old Dec 12, 2009 | 04:42 AM
1GR8350Z's Avatar
1GR8350Z
+ 1
Old Dec 12, 2009 | 05:06 AM
Ziggyrama's Avatar
Ziggyrama
To the OP, don't hack your suspension or you'll end up regretting it: compromised handling, poor ride comfort, premature wear on the dampeners. Do you just want the drop in the front for the looks? From what I can tell, most people report destroying their stock shocks very quickly after a spring change, even with modest drop. So, you won't save much by just doing the springs because you'll be buying shocks shortly thereafter and paying for double alignment and installation.
Generally, springs have to be matched to dampeners in order for them to work correctly. Stock shocks are matched to stock springs. If you change the springs, you change the balance which will most likely result in poor dynamics. Suspension is a complicated science so take your time and do it right. And by doing it right, I don't mean just buying coilovers. Be prepared to deal with things like camber and toe which will change once you alter the stock setup. Stock setup has very limited set of adjustments so you'll probably have to factor in additional parts to account for that.
Old Dec 12, 2009 | 06:20 AM
StevieZ's Avatar
StevieZ
You need to invest in coil overs with adjustable height
Old Dec 12, 2009 | 06:32 AM
*Boose*'s Avatar
*Boose*
If you buy from ebay don't ever post here again. Buy a set of stance coilovers or tein basics. Both are available for under 1k.
Old Dec 12, 2009 | 08:13 AM
Ziggyrama's Avatar
Ziggyrama
He does not. He needs to find correct spring/dampener combo. Coilovers can be the option but they are not ncessary.
Old Dec 12, 2009 | 09:24 AM
fart_canon's Avatar
fart_canon
I suggest you SEARCH.
Old Dec 12, 2009 | 03:40 PM
Cubhazl19's Avatar
Cubhazl19
Talking Great replies!
Alright guys, I think that's enough info. for now. Thanks for all the comments, and I will definately use all of the advice and do my research!
But know this, my ride will look sick!!!!! THANKS AGAIN!!!
Old Dec 12, 2009 | 09:25 PM
*Boose*'s Avatar
*Boose*
Mhmm sick and horrible.
Old Dec 12, 2009 | 09:50 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Coilovers.. I have Eibach and they ride great cinsidering the level of drop I have.
Old May 25, 2010 | 01:58 PM
Oh man I wanted to see a raked 350Z with the *** sticking in the air.
3vilbunny
Jul 18, 2017 05:10 PM
_bit
Oct 2, 2015 07:49 AM
Mattg350z
Oct 2, 2015 06:51 AM
