Brake Sounds : (
Old Dec 19, 2009 | 07:05 PM
TTwinTTurbo's Avatar
TTwinTTurbo
Default Brake Sounds : (
To give a little background information the car is a 2003 Track Model so it has the brembo brakes. I noticed that there is an intermittant grinding sound that just started happening. I also know that the pads are very low as the dealership said that I should get them changed in the next 5k miles. I looked around the calipers and felt them and I don't notice any groove marks. There is no etching on them as if they started grinding into them or something.
I have brake pads on the order and am going to swap them out monday and am not driving the car until I change them.
My question is do you guys think that the calipers are messed up or something? Like I heard they built a safety mechanism into them that will make a weird sound to let you know that they need to be changed. Any help would be wonderful I will be checking this forum off and on tonight but alot.
Old Dec 19, 2009 | 10:22 PM
*Boose*'s Avatar
*Boose*
Um wow sounds like your hitting the pad sensor.
Old Dec 19, 2009 | 10:32 PM
There is no inspection window in the Brembo calliper, so you cannot see the pad. The noise made by the wear sensor to rotor is distinctive - easy to recognise.
How do you know when a rotor must replaced? You measure the thickness.
Old Dec 19, 2009 | 10:53 PM
TTwinTTurbo
Thanks for the help. I know that sometimes the rotors need to be replaced even if they are a 10th of a milimeter out of spec...I was thinking about just swapping the pads...like whats the worst that could happen? I was thinking it might wear the pads a little faster than normal. I'm find with that right now until I can get high performance rotors.
Old Dec 19, 2009 | 11:11 PM
There are some complicated tests like
run out
and wear deviations
but most members just go with thickness.
Old Dec 20, 2009 | 12:31 AM
TTwinTTurbo
I always wondered. I just kinda feel like sometimes I'm getting robbed when they replace all the rotors when they look fine and I wasn't hard on them. I'm gonna try just re-installing the pads and hoping nothing happens
Old Dec 20, 2009 | 05:09 AM
This is a money saving tool.
Obadabot
Jun 18, 2023 11:31 PM
