coilover problem
Old Jan 6, 2010 | 05:33 PM
mrfobbyaccent's Avatar
mrfobbyaccent
Default coilover problem
Hey everyone. I tried to use the search bar to find pictures of how a oem rear coilover setup looked like, but couldn't find any. Is it possible for some people to post up pictures of the oem rear coilover setup. My problem is I went to a shop today to get my fenders rolled and they said whoever installed my coilovers installed the spring on backward. i don't have any pictures of it at the moment. I will post some up as soon as I can though. Any pictures for now would be greatly appreciated. Ohh another question is do we have to use the stock spring mount with the oem rear coilover system? I thought we didn't have to because the adjuster replaces it. Also do we adjust the shock when we lower the rear, because mine has a huge gap between the spring and the body when the car is lifted off the ground. The gap is almost big enough for the spring to just pop out. Any help would be greatly appreciated thanks a lot everyone!!!!
Old Jan 6, 2010 | 08:40 PM
mrfobbyaccent
sorry guys does anyone know anything on this? Sorry I want to fix this problem as soon as i can sorry!!!
Old Jan 7, 2010 | 05:11 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
every coilover is different
refer to the instructions that came with your coilovers, or contact whomever manufacturs/sells your coilovers
Old Jan 7, 2010 | 10:43 AM
mrfobbyaccent
The coilovers didn't come with instructions.
Old Jan 7, 2010 | 10:46 AM
Z1 Performance
Former Sponsor
then move to step 2 of my suggestion
Old Jan 7, 2010 | 11:00 AM
JasonZ-YA's Avatar
JasonZ-YA
oh man, to help you out we really need pics.........
my #assumption is that the *competent tech is probably right about something not being installed right. but Z1 is correct..........some coilover systems utilize the stock spring locations, others dont....they are a complete coilover mounted at the "oem shock" location only and the spring location is just NOT used...arm is still used though.
get us some pics and we can help...people like Z1 have installed tons of them and would most likely know exactly what set up you have with a few GOOD pics and be able to help ya out..
-J
Old Jan 7, 2010 | 12:22 PM
terrasmak's Avatar
Did they come with a BRAND NAME , that might help us out. Or are they just called coilovers?
Old Jan 7, 2010 | 12:39 PM
mrfobbyaccent
-J
Yeah thanks a lot Jason I will get some pics ASAP!! Ill probably do it right now.
As for the brand SMA
Old Jan 7, 2010 | 12:42 PM
Z1 Performance
Former Sponsor
never heard of them
why not just call the manufacturer/seller? surely they would (should) know?
Old Jan 7, 2010 | 12:53 PM
GeauxLadyZ's Avatar
GeauxLadyZ
http://www.smasus.co.kr/e_contact.php
Old Jan 7, 2010 | 07:30 PM
mrfobbyaccent
thanks for all the response everyone, I will try to post some pics up by tomorrow!!
Old Jan 9, 2010 | 08:49 PM
jkebun's Avatar
jkebun
i've been talking to mrfobbyaccent and am also rolling on the sma coilovers. darin from west end installed my coilovers and used the rear rubber cone upper spring mount because w/o it, there would be too much play. the lowest my rear will drop is a 3-finger gap running 265/35-18. in mrfobbyaccent's case, his installer did not include the oem upper spring mount in the rear. he was able to slam his rear, but now has WAY too much play in the rear, which is bad because the spring can and probably will pop out eventually. the sma's quality is really good and my z handles great, but the main problem is that the coilovers dont come with any literature and that the company is based in korea and doesnt have a US branch/headquaters
Old Jan 9, 2010 | 10:59 PM
jkebun's Avatar
jkebun
i've been reading other threads and decided im going to try adjusting/shortening the rear damper itself. only the spring seat was adjusted to the maximum lowest setting and the damper was left untouched. (oem type rear)... sh@t!!!! i just got the z corner-balanced and alignment 4 days ago too. gonna be throwing everything outta spec...
this isn't the final setting, i just took a picture of it as soon as Darin put it in. he adjusted the spring seat for maximum drop but still only achieved a 3 finger gap at best. im going try shortening the damper tomorrow.
Old Jan 10, 2010 | 08:48 AM
terrasmak's Avatar
^find someone who knows what their doing, thats not even close to being adjusted for max drop. Second , the gap will also go away if you removed the front tires from the rear of the car.265/35-18 is a front tire size and 1.5inches to short for the rear.
Old Jan 10, 2010 | 08:54 AM
zrzly?'s Avatar
zrzly?
read the post, he says it's not the final adjustment on the sleeves. and....this might sound stupid, but "front tire size"? is the Z regulated to what size tires it can and can't run front and rear? maybe that 265/35 is stretched onto something (doubt it, but never know). either way, one thing i learned is that with OEM type systems it seems that the drop is never enough for people expecting to slam their cars. another thing to consider, is to cut that rear spring mount, I've seen people take as much as 1/2" out of it, but remember there's a reason the rear sits a bit higher than the front. either way, it'll all get figured out.
Old Jan 10, 2010 | 09:27 AM
Z1 Performance
Former Sponsor
Interesting that whomever sold you the coilovers can't walk you through how to install them and/or adjust them. It shouldn't be so hard that 2 people have the same units, one with the rear cone, one without, and neither one of them have the height adjusted correctly.
Old Jan 10, 2010 | 09:42 AM
zrzly?'s Avatar
zrzly?
as stupid as it's gonna sound, a three finger gap sounds HIGHER than factory. make sure you're adjusting the collars the right way. i'm only saying this because the first set I ever installed i had the collars on upside down and couldn't figure out for the life of me why they didn't sit lower.
Old Jan 10, 2010 | 10:39 AM
jkebun's Avatar
jkebun
i shortened the rear dampers last night and it seem to work. the only problem is that i was able the shorten the damper by about half an inch max. maybe i just ran outta strength haha. gonna keep messing around with it and see what happens
Old Jan 10, 2010 | 05:21 PM
mrfobbyaccent
That is exactly how mine sits, the spring is just sitting there. I was going to try adjusting the shocks, but i haven't had time to. I am going to try and do the same when I have some time. Thank you soo much.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
