Upgrading the stock brakes
Old Feb 11, 2010 | 10:24 PM
Jeff92se's Avatar
Jeff92se
A PROPERLY engineered front only bbk would be a great starting point. Stoptech has a front only kit that's designed with the right rotor dia/piston sizes and piston numbers to keep the front/rear bias in check.
Old Feb 12, 2010 | 09:33 AM
maXmood's Avatar
maXmood
Under Boost!
i think i just found a good deal on ebay for Wilwood's...
what's the oem Brembo specs?? 4 front, 2 rear?
Old Feb 12, 2010 | 09:52 AM
maXmood's Avatar
maXmood
Under Boost!
the kit i found (new),
4 piston front/rear, with SS lines + pads, without rotors = $1,250
what do u think?
Old Feb 12, 2010 | 10:00 AM
ITOzann's Avatar
ITOzann
^ hell of a deal! wonders what rotors, pads, and lines are included? 1250 for a front and rear set up? didn't know Wilwoods go that low
Old Feb 12, 2010 | 10:16 AM
Jeff92se's Avatar
Jeff92se
I think you need to make sure it's sized correctly.
Old Feb 12, 2010 | 10:32 AM
maXmood's Avatar
maXmood
Under Boost!
that's without rotors.. so about 400 for rotors?
dunno what brand of pads i'm getting. i gotta ask..
the only down side of this deal is they come in Black, and i want them in red....
he offered to PC them for $50 each..
that's about $1850
on the other hand, i found 4 oem brembo calipers (almost new) for around $1100.. no rotors, no pads, no lines, just calipers..
so if i go with that, then i need to buy rotors (around $400??) + pads (dunno how much), and brake lines (dunno either)..
so, i'm expecting something around $2000 to make the kit complete.
at this point, i prefer to go with OEM brembo's over Wilwoods.. just a personal reference.
what you think?
Old Feb 12, 2010 | 11:15 AM
TheFarmer's Avatar
TheFarmer
Originally Posted by maXmood
t
That's expensive for just calipers. I purchased a set of OEM Brembo calipers for my brother's Z from a member on here awhile ago for about $750 shipped.
If you get just the calipers you will need the Brembo hardware kit (the pins and clips), SS lines, brake pads, rear bolts, rotors...you'll spend easily another $600+ for everything needed to install the calipers.
You should really consider the Akebono kit. I think it's a great kit with the right rotor/pad combination. For $2139 you get f/r 14" Stoptech rotors, Akebono calipers, SS lines and everything needed for install. Or $1700 for the f/r kit with no rotors so you can chose your own rotor/pad combination.
https://my350z.com/forum/brakes/4142...at-1200-a.html
Old Feb 12, 2010 | 12:36 PM
Zazz93's Avatar
Zazz93
I'm gonna have to wait on my kit, but SPL had a front and rear Black Stoptech set for a good price. You might be able to get him to break up the clearence sale and get fronts only for a little more than the 1k you have now. I'll forword you the PM.
Old Feb 12, 2010 | 05:54 PM
ITOzann's Avatar
ITOzann
If I were you I'd pay 1k for a front used stoptech set up and wait for the rears as time goes. Best investment ever made. I purchased fronts only and don't even know if I want to upgrade rears :P since performance is amazing! Anyways, Gluck with whatever you get. Just make sure you get something you are happy with..
EDIT: check this out https://my350z.com/forum/norcal-mark...lwood-bbk.html
