excessive body roll
Old Feb 18, 2010 | 01:46 PM
fall0ut's Avatar
fall0ut
Default excessive body roll
about 2 months ago i began noticing a crackling sound. to me it sounded like a spring shifting either compressing or decompressing... i only hear the sound when weight shifts around the car... like opening a door, getting out of the car, one wheel being elevated higher or lower than the others...
i was a little annoyed by the noises, but figured it was just something the cold weather was causing... about a month ago i replaced all four Michelin pilots tires with hankook v12's. before and after wheel alignment i noticed more body roll when changing lanes and turning.
i am using the same size tires and the same tire pressure as before with the michelin's. i havent had any traction problems on wet or dry roads.
although i didnt notice the body roll issue before replacing the tires, could it be a suspension problem? as far as i know the entire suspension setup is stock... although other Z owners have said my car sits a lot lower than their stock Z's...
i have tried manually pushing down over a wheel well to check for excessive bounce... it didnt bounce.
Old Feb 18, 2010 | 01:51 PM
0jiggy0's Avatar
0jiggy0
Take the car to a shop and have the suspension checked.
Old Feb 18, 2010 | 01:54 PM
fall0ut's Avatar
fall0ut
will do.. thanks for the fast reply...
i enjoy your avatar.
Old Feb 18, 2010 | 02:00 PM
DavesZ#3's Avatar
DavesZ#3
Could be swaybar too. Definitely get it checked.
Old Feb 18, 2010 | 02:20 PM
One important fact you are omitting. How many miles?
Old Feb 18, 2010 | 07:01 PM
gregom's Avatar
gregom
Could be a broken endlink and your swaybar is no longer properly attached. Should look the similar in the back. This pic is my front right side.
Old Feb 18, 2010 | 07:07 PM
Goku350z2007's Avatar
Goku350z2007
You could be having some vertigo problems, lol
Obadabot
Jun 18, 2023 11:31 PM
