suspension clunking noises !!!!!!!!
Old Mar 24, 2010 | 07:31 PM
jprada26's Avatar
jprada26
Default suspension clunking noises !!!!!!!!
need some help!!! i have an 07z witch had eibach sportline springs and decided to go back to stock. now that i threw the stockers back on every single bump, small pot hole ,speedbump, or any uneven surface i go over theres a clunking noise that comes from the suspension. " mostly the back " . help please....
Old Mar 25, 2010 | 12:56 AM
duro78's Avatar
duro78
its your rear endlinks.
Old Mar 25, 2010 | 07:22 AM
jprada26's Avatar
jprada26
il check it out hopefully it that .... does it have to be replaced ? .........
Old Mar 25, 2010 | 05:57 PM
SniperHunter's Avatar
SniperHunter
Does it sound like this:
http://www.youtube.com/watch?v=CM2Py...layer_embedded
If it does, I can tell you how to fix it. We have finally discovered the fix in a repair thread.
Old Mar 26, 2010 | 06:22 AM
jprada26's Avatar
jprada26
i cnt see the vid in my work comp. il check it out when i get home ..
Old Mar 26, 2010 | 11:29 AM
jprada26's Avatar
jprada26
just saw the vid, but its not nearly that loud
Old Mar 26, 2010 | 11:57 AM
SniperHunter
For some it's louder than others. If it's a faint clunking then it likely is endlinks. If it's more than that, try this simple fix here:
https://my350z.com/forum/maintenance...n-rear-14.html
Scroll down to post 265.
Before filling in that gap with a spacer made of PVC, re-torque down those bolts tight and take a drive. If the sound goes away, that's your problem. You can then go back and do the spacer fix. If it's still there, check your endlinks for excessive play.
Old Mar 28, 2010 | 07:32 AM
jprada26's Avatar
jprada26
thanks , i appreciate the help. il let you know what it was as soon as i get the chance..
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
