ok guys i swapped my non brembo calippers to brembo ones i changed the lines , rotors, brake pads , etc. After i bleed all the lines for any air etc and toped of the fluid for my brakes After i truned on the car to make sure everythign is ok i noticed that my Red brake light had come on ... ???
what is that for i think it the same brake light that hand brake uses ...
please any help would be apritiated, is this normal ? will it just go away ?
Aren't you the guy who is also having trouble with the VDC and Slip lights too? If all of them are on, then you have some serious issues with the ABS system.
yes but those lights were on before my brake light even came on , and thats only because of the brake job i did so i'm wondering if that had anything to do with it
