swaybar settings
Old Apr 7, 2010 | 08:07 AM
nismospec's Avatar
nismospec
Default swaybar settings
ok, it's been reviewed a million times I know....
but i have the Hotchkis TVS stage 1 package, with Tokico Hp's, and SPL rear camber and toe kit.
my front swaybar is set on the 3rd stiffest setting (i have the revised with 4 holes), and the rear is on the middle setting.
the rear of my car feels solid and great, but the front is sluggish. i'm looking for more response from the front and a quicker turn in.
is it the front swaybar that I need to set to soft, or do i need to play with the rear settings in order to achieve a sharper feel up front?
thanx
Old Apr 7, 2010 | 09:42 AM
350junkie's Avatar
350junkie
toe out(or in...can't remember) will give you a quicker turn-in but will also reduce high speed stability to a point, and create tire wear
sways just reduce the roll from side to side under turning situations
Old Apr 7, 2010 | 10:43 AM
plumpzz's Avatar
plumpzz
What tire pressure are you running at? What tires are you using? What wheels? What setting are your Tokikos at? Did you preload the front sway bar and the rear sway bar?
Old Apr 7, 2010 | 10:54 AM
nismospec's Avatar
nismospec
35 psi all the way around. stock size tires front and rear running Hankook Ventus Evo's, Tokicos are the HP's so they are not adjustable (the blue ones), and no clue on the preloading of the sways. I'd imagine so being that they were installed at a reputable shop that specializes in Nissans.
Old Apr 7, 2010 | 12:12 PM
terrasmak's Avatar
How wide are your rear tires, and what size?
Old Apr 7, 2010 | 12:41 PM
nismospec's Avatar
nismospec
see above
ok, not trying to be a smart @ss, I did just realize that different year Z's have different sizes, but mine are 225/45 18" up front and 245/45 18" in the rear.
Old Apr 7, 2010 | 01:40 PM
DavesZ#3's Avatar
DavesZ#3
I saw the greatest improvement in turn-in when I went to a zero-toe setting on the front.
As everybody has pointed out, there are so many factors that affect handling besides the swaybar. It's ususally not as simple as setting swaybar, shock and alignment based on what others are using unless they have the exact same setup. You're going to have to experiment around a little.
Old Apr 7, 2010 | 02:40 PM
nismospec's Avatar
nismospec
sounds good. i'll have to research a bit more.
i have read that certain settings cause oversteer and understeer.
so is it stiff front, soft rear that causes understeer, or vice versa?
Old Apr 7, 2010 | 03:32 PM
DavesZ#3's Avatar
DavesZ#3
Here's where it get's tricky.
In the classic definition, a stiffer front sway increases understeer. On our cars, because of the limited camber, we normally go stiffer to help prevent body roll which tends to lean the tires more. It's counter-intuitive to what you want but it works.
I have hotchkis sways and use 3rd hole front (medium-stiff) and 1st hole rear (full soft). I have stock springs and Koni adjustables so you can't make a direct comparison to your setup.
I'd recommend browsing the threads on the Autocross/Track forum - there's a lot of them on swaybar settings, track setups, etc. You'll get a feel for what people are using and why from them.
Old Apr 8, 2010 | 06:26 AM
JasonZ-YA's Avatar
JasonZ-YA
agree on those two post.........
-J
