Bedding new pads/rotors
Old May 2, 2010 | 07:40 PM
AznSky's Avatar
AznSky
Default Bedding new pads/rotors
Ok so I've been reading up on this all day and I think it's ok, but just wanted to make sure.
Yesterday i installed carbotech pads, new rotors, fluid, and ss lines. Went to bed in the pads and rotors today and followed carbotechs instructions. After I got out the car, I noticed my rotors had turned blue on the inside. Maybe I got the brakes too hot. But stoptechs website says it's better to get them hotter than not hot enough. And all four corners got like that, so that means if I have a stuck caliper, then all four are stuck.
After proper cooling, the brakes feel perfectly normal with no vibrations and noises under normal driving.
So did I ruin the rotors or cook the pads? Or am I just paranoid? Hopefully the latter
Old May 2, 2010 | 09:24 PM
Chebosto's Avatar
Chebosto
you should be ok.. its normal for some slight discoloration in new rotors right after bedding.
did you 'smoke' the pads and do the proper cool down? seems like you did if there were no vibrations/noise
Old May 3, 2010 | 04:30 AM
AznSky's Avatar
AznSky
thanks for the reply Cheston. I'm pretty sure they're fine, just needed a more experienced guy to say so to put me at ease
Old May 4, 2010 | 11:45 AM
RAYZ33's Avatar
RAYZ33
You did it properly.
Search on youtube, I think APracing did a whole video for the proper bed in procedure with technical specs, FAQs, the works.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
peptidbond
Aug 24, 2003 04:41 PM
barrybell
Aug 3, 2003 03:53 PM
MaddMatt
Apr 20, 2003 06:24 AM
