stoptech big brake kit my 06 track (HELP)
Old May 30, 2010 | 11:19 PM
simonkim's Avatar
simonkim
Default stoptech big brake kit my 06 track (HELP)
I tried installing stop tech bbk, but ran into some problems.
1. the bracket for the rear is a couple millimeters off. Tried everything, but nothing would work. has anyone run into this problem?
I have the st45 in the rear. and st40 in the front.
Old May 31, 2010 | 12:26 AM
OMERTAITALIA's Avatar
OMERTAITALIA
u mean st45 in the front?
Old May 31, 2010 | 06:20 AM
bimmertech's Avatar
bimmertech
no, he means st45 rear--just like he wrote.
op, this may be a stupid question but have you tried swapping the brackets from one side to the other?
Old Jun 1, 2010 | 10:17 AM
StopTech's Avatar
StopTech
Vendor - Former Vendor
details overwhelming...
Off a couple of mm in which way?
What is "everything"?
Or just give us a call. We'll help you sort through this.
Old Jun 3, 2010 | 10:13 AM
simonkim's Avatar
simonkim
ehhh. i just found out imma a dumbass. I have the track edition z. the caliper bracket is different. Im going to take a $560 hit for being imulsive. Live and learn. haha
Simon
Old Jun 3, 2010 | 10:16 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
^what? people swap oem brembo's all the time to cars that dont have brembos and all that is different is the rear bolts.
Old Jun 3, 2010 | 10:23 AM
TheFarmer's Avatar
TheFarmer
Caliper bracket for ST45s should be the same for base or Brembo equipped car.
EDIT: You also realize that with the ST45s, you are required to trim the back mounting "ears" until they are flush with the brackets right? If you don't trim, factory mounting tabs will stick out a few mm.
Old Jun 3, 2010 | 12:52 PM
StopTechErik's Avatar
StopTechErik
The install is the same whether or not its a track model.
Check page 11 of the manual here:
http://www.stoptech.com/tech_info/ma...46.1451.07.pdf
Might be what you are missing.
samansharif
Sep 25, 2015 12:31 PM
