Would a 1" drop work on my car?
Old Jun 1, 2010 | 08:33 AM
lowcel's Avatar
lowcel
Default Would a 1" drop work on my car?
I would like to drop my car but I want to make sure that I won't have any problems before I order the springs. I am running 20" wheels and the rears are 275/30/20's and the fronts are 245/30/20's. Also, would I need anything besides springs if only going down 1"?
Old Jun 1, 2010 | 10:30 AM
duro78's Avatar
duro78
You can lower it but you will need camber bars for the rear to get back into spec depending on what springs you chose. You need spacers badly your stance will make your car look a lot better
Old Jun 1, 2010 | 10:53 AM
lowcel's Avatar
lowcel
Thanks for the reply. Can you recommend a good place to pick up the spacers? Also, if I go with the Eibach Pro Springs will I need the camber bars?
Old Jun 1, 2010 | 11:58 AM
03threefiftyz's Avatar
03threefiftyz
If you keep at an ~1" or less camber arms are a 100% necessity. I would look into a 15mm spacer all around, but be aware that you will need to get ones that come with extended studs.
Old Jun 1, 2010 | 01:11 PM
Black Z Eddie's Avatar
Black Z Eddie
As for the spacers, I would get the bolt ons. There are several brands, but, I know of Ichiba. The below link will show you how to measure. Then, scroll down to select the one for your Z.
http://ichibausa.com/whspveii.html
Old Jun 2, 2010 | 04:04 AM
lowcel's Avatar
lowcel
So does that mean that over 1" camber arms are not necessary?
Old Jun 2, 2010 | 04:05 AM
lowcel's Avatar
lowcel
Thank you.
Old Jun 2, 2010 | 02:40 PM
lowcel's Avatar
lowcel
I decided to go with coil overs so I can adjust the drop the way I want it. Hopefully they will be worth the extra money.
Old Jun 2, 2010 | 02:54 PM
1 inch would be perfect.
Old Jun 2, 2010 | 03:10 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
U need to SLAM it. and also get new tires
Old Jun 2, 2010 | 03:11 PM
Waiz's Avatar
Waiz
I know I already stated it, but those tires look weird.
Old Jun 2, 2010 | 03:13 PM
2004Black350z
Exhaust Whore
my buddy has a G35 with Cut springs SLAMMED on 20s (8.5F,9.5R) with rolled fenders and i think 40 series tires and it looks sick
Old Jun 5, 2010 | 07:15 AM
lowcel's Avatar
lowcel
Here it is after the coilover install. It is dropped right at an inch all the way around. I will be ordering the camber bars in the next day or so.
Old Jun 5, 2010 | 07:19 AM
2004Black350z
Exhaust Whore
thats looks a lot better
Old Jun 5, 2010 | 10:57 AM
Black Z Eddie
Wow, what a difference. Even at 1", I have to admit, going by the pic, the camber looks fine.
Old Jun 5, 2010 | 11:01 AM
lowcel's Avatar
lowcel
Thanks guys. Unfortunately the camber was screwed up before I even did the drop. The insides of the rear tires are in pretty bad shape already.
Old Jun 5, 2010 | 11:06 AM
2004Black350z
Exhaust Whore
what are u buying? Front and rear camber kit?
Old Jun 5, 2010 | 11:09 AM
lowcel's Avatar
lowcel
Just planning on a rear for now.
Old Jun 5, 2010 | 11:28 AM
Black Z Eddie
When you say bad shape, do you mean excessive wear compared to the other parts of the tire? If so, it's probably a toe problem (too much toe-out in this case). Camber does affect the tire wear (duhh), but, a bad toe adjustment is 100x worst.
Last edited by Black Z Eddie; Jun 5, 2010 at 02:13 PM. Reason: I meant toe-out, not toe-in.
Old Jun 5, 2010 | 07:30 PM
lowcel's Avatar
lowcel
Thanks, I'm planning on getting the camber/toe package on the vender classifieds on here.
Took a couple of better pictures this evening. I need to get some good shots later but these will hold me over until then.
Chris350z03
Oct 8, 2023 07:19 PM
etkms
Jun 19, 2022 06:30 PM
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
Ronso
Oct 30, 2015 12:39 PM
smithmt3
Sep 11, 2015 08:25 PM
