Question about springs
Old Jul 8, 2010 | 07:26 PM
350_DRIVEHARD's Avatar
350_DRIVEHARD
Default Question about springs
I have an 05 350Z and want to lower the car some with springs without having to change the shocks. I was looking at an eibach lower kit at one of the sponsor sites http://www.injectedperformance.com/e...ct.aspx?ID=572. Does anyone know if I can just change out my springs and that be it and does anyone know how much this would lower the car because the website doesn't say. Lastly wow do I need something to adjust my camber? Thanks.
Old Jul 8, 2010 | 08:30 PM
Yes however you will have to take apart the front spring-damper assembly. It is a spring over a damper. Example above.
Old Jul 9, 2010 | 05:42 AM
zaperroni's Avatar
zaperroni
i believe if the drop is over an inch, you will need a camber kit.
but i am not sure lol
Old Jul 9, 2010 | 08:20 AM
Gsedan35's Avatar
Gsedan35
Here's a cut and paste from my master list of 350Z aftermarket springs, it lists drop amounts.
2004.5+ 350Z Oem spring rates
314/427
Eibach 350Z progressive springs 1”/1”
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
Eibach 350Z sportline progressive springs 1.2"/1.2"
F: 239/400 R: 257/435
Very wide spreads between the softer initial rates and firmer peak rates.
RSR 350Z linear springs .6”/.6”
Spring rates in LBS 345/417
Hotchkis 350Z Linear springs .6”/.8”
Spring rates in lbs 340/330
Tein S-tech 350Z springs .7“.6“ (fronts are slightly progressive, rears are linear)
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
Tein H-tech 350z linear springs .3”/.2”
Spring rates in LBS 358/375
Progress Technology progressive springs 1.0”/1.0”
Spring rates in LBS 425/385 (final rates only, softer intial front progressive rate unknown)
350Z Tokico D-spec shock & spring package 1"/1.5" drop Kit part# DSK512
Spring rates 375/375 linear springs
Tanabe GF210 Series 350Z progressive springs 1”/1.2”
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown) Not much stiffer vs oem, IMO Eibach prokit is a better choice because of that springs higher spring rates which should help keep you off the bumpstops more often.
Tanabe NF210 Series 350Z progressive springs 1.2”/1.2” higher
Spring rates in LBS 314/353
Little to no increase in spring rate over oem, little to nothing added to keep you off the bumpstops
Swift 350Z linear springs .8”/.6”
Spring rates in LBS 336/364
Swift 350Z Spec-R progressive springs 1.2”/1”
Spring rates in LBS intial/final Front: 291/392 Rear: 280/448
Nismo T2 350Z Linear springs 1”/1”
Spring rates in LBS 625/700
Way too much spring for oem shocks or Tokico D-specs, Tokico HP, KYB GR-2 or off the shelf Koni yellows/Bilstein HD. TcKline DA shocks were specfically designed for these springs.
Vogtland 350z progressive springs 1”/1”
Spring rates in LBS initial/final front 257/354 initial/final rear 285/422
Espelir 350Z progressive springs 10mm drop F&R
386/515 (softer initial progressive rates are unknown)
H&R sport progressive springs 350Z 1.3”/1” drop
Spring rates in LBS 370/400 (peak rates only, softer initial rates are unknown)
Skunk2 350Z progressive springs 1.3”/1”
Spring rate in LBS 238/381 237/395
Old Jul 9, 2010 | 08:47 AM
sluggoZ's Avatar
sluggoZ
I'm also thinking about springs....I'm leaning towards Hotchkis Sport Springs...using stock struts and springs are linear rate as are stock.
Intensepower seems to have the best price too!
issyz
Jul 2, 2017 03:04 PM
