anyone replace their front tie rod?
Old Jul 22, 2010 | 06:52 PM
ac419's Avatar
ac419
Default anyone replace their front tie rod?
i was wondering if anyone replace their front tie rod. if so, what did you use and how much did you pay? when i took my car into get an alignment.. my mechanic showed me my front wheel wobbles a little tiny bit.. left vs right side. is this something the mechanic can tighten up? or will i have to get a new one? thanks.
-Alex
Old Jul 23, 2010 | 03:08 AM
DavesZ#3's Avatar
DavesZ#3
The Z doesn't have a plain tie-rod. It's all part of the steering rack. Check this diagram out...
CLICK HERE
Old Jul 23, 2010 | 03:55 AM
winchman's Avatar
winchman
Looks to me like you can replace either the inner tie rod (49521K) or the outer tie rod (49520K), depending on where the looseness is. Just to be on the safe side, it's probably best to replace any part that has enough play to be seen. You'll have to remove the boot on the end of the rack to inspect the inner joint.
There's no way to adjust them to make them tight again.
Old Jul 23, 2010 | 05:58 AM
ac419's Avatar
ac419
so it's probably best to replace both the inner and outer rods?
Old Jul 23, 2010 | 06:10 AM
winchman's Avatar
winchman
I'd think that if one is bad, the other can't be far behind.
Old Jul 23, 2010 | 09:01 AM
Z_flip's Avatar
Z_flip
http://www.more-japan.com/home.php?cat=619
Old Jul 23, 2010 | 09:33 AM
Kwame's Avatar
Kwame
Tein Tie Rod Set - Includes outers and inners which are 5mm longer than stock...
http://z1auto.com/prodmore.asp?model...ng&prodid=2931
SPL Outers...
http://z1auto.com/prodmore.asp?model...ng&prodid=3968
Old Jul 24, 2010 | 07:01 AM
ac419's Avatar
ac419
SPL Outers...
which one is better kwame? thanks.
Old Jul 24, 2010 | 12:26 PM
Kwame's Avatar
Kwame
Really depends on the use. We have the Tein setup on Adam's car and they work just fine. Keep in mind one is a complete set and one is just the outers.
Old Jul 25, 2010 | 08:42 AM
ac419's Avatar
ac419
so when i purchase this do i need to order 2 sets for both the right and left? or just 1 set? thanks
Old Jul 25, 2010 | 07:03 PM
Kwame's Avatar
Kwame
One set per car.
Old Aug 4, 2010 | 03:36 PM
solidfish's Avatar
solidfish
When I bent my TRE the local shop quoted me $300+ for the job. I ended up doing it myself. Pretty easy except you need a special tool. I was able to rent the tool at Kragen (oriely) for free. Just tell them its for a TRE.
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Dymsi
Sep 29, 2015 11:32 AM
samansharif
Sep 25, 2015 12:31 PM
