Function Form Owners Please Help
Old Aug 20, 2010 | 06:20 AM
htownimports's Avatar
htownimports
Default Function Form Owners Please Help
just a quick question, posted in the Springmount thread but no luck, did you guys leave the springmount in or not? mine isn't slammed at all with them on but dont want them sqeeking with them off, just want to figure this out before doing the springmount mod, thanks in advance.
Old Aug 20, 2010 | 08:12 AM
User 42426's Avatar
User 42426
i don't have function and form, but I do know these coils are supposed to slam your car. Is that the lowest it will go? Why don't you just drop it some more without taking out the spring mount?
Btw, I don't think taking out the spring mount will cause squeaks. A lot of the spring owners have done this mod.
Old Aug 20, 2010 | 12:01 PM
X.et's Avatar
X.et
They install like most other oem style coilovers where the perch takes the place of the springmount. So basically it will be upside-down in there and the bottom of the spring will fit into the indentation for the spring in the spring bucket. Assuming g35 is the same as the 350z which I'm 99% sure it is.
Old Aug 20, 2010 | 01:05 PM
sdZ33's Avatar
sdZ33
Try asking the guys in the aggressive wheels stretched tire thread.... Im positive someone there has these c/o's
Old Aug 20, 2010 | 05:42 PM
User 42426's Avatar
User 42426
im confused now. I thought he was refering to the rubber spring mount in the rear, to lower the rear even more. But the comments talk about the spring bucket?? if the coils are oem style, don't take out the spring bucket/spring. If it is true coils, it will HAVE to replace the spring bucket with arms.
Old Aug 20, 2010 | 06:49 PM
X.et's Avatar
X.et
I don't understand what are you talking about? OEM style coilovers you remove the spring and springmount, not talking about removing the spring bucket at all. I think the OP just has the rubber springmount left in where as at least on the g35 it has to be taken out. Unless he is talking about the lower spring seat in the spring bucket, that stays. Here is a picture of how they get setup (not mine), hopefully this helps explain how things should be.
And I have f&f coils on my g and I can definitely at least set my frame on the ground.
Old Aug 20, 2010 | 11:36 PM
SQBassHead's Avatar
SQBassHead
op these coils are made to lay the frame to the ground, im lost!!!>>>LOL<<<
Old Aug 21, 2010 | 06:31 PM
htownimports
yeah i got them because they are known to slam.....i'll flip the coil to where the perch is on top and remove the springmount, we'll see how it goes from there, thanks to everyone for chimming in!
Old Aug 21, 2010 | 06:54 PM
sdZ33's Avatar
sdZ33
Please post results
Old Aug 22, 2010 | 08:12 AM
X.et's Avatar
X.et
I installed it the same way as you at first then I saw how they were supposed to be and my car instantly dropped to the floor. I'm probably close to 3/4th as high as I can be and my car is pretty dang low. Picture to show what I mean (I am a tiny bit higher than this right now)
Old Oct 2, 2010 | 07:48 PM
htownimports
okay i finally had time to play around with the coilovers, i dont think im suppose to removed the springmount, after doing so, the car was literally on the ground but after driving around, i can hear the coilover squeaking or moving around, it was ridiculously loud, so i decided to do the springmount mod, which dropped it the way i wanted and removed the noise, hope this helps others
Old Oct 10, 2010 | 06:03 PM
i3aog's Avatar
i3aog
I just got F&F coils as well, please post pics...
Justin100
Nov 25, 2021 06:26 AM
Jambo016
Sep 16, 2016 01:08 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
Tochigi_236
Sep 27, 2015 03:40 PM
