stuck rotor
Old Sep 4, 2010 | 02:30 PM
rick7340's Avatar
rick7340
Default stuck rotor
my rear right rotor is stuckand will not come off. iv takin the e-brake off and the rotor spinds freely. any suggestions how to get it off!
Old Sep 4, 2010 | 03:40 PM
winchman's Avatar
winchman
From the service manual section PB:
REMOVAL
WARNING:
Clean brakes with a vacuum dust collector to minimize the hazard of air borne particles or other materials.
Be careful of the following:
 Remove the disc rotor only with the parking brake lever completely in the returned position.
 If disc rotor cannot be removed, remove as follows:
1. Fix the disc rotor in place with wheel nuts and remove disc rotor
plug. Using a flat-bladed screwdriver, rotate star wheel on the
adjuster assembly in direction “B” to retract and loosen brake
shoes
Direction B is the handle of the screwdriver going up as you're turning the start wheel.
Old Oct 18, 2010 | 09:31 AM
thekinn's Avatar
thekinn
this topic has been covered a few times.. search 'rear rotor stuck'
https://my350z.com/forum/search.php?searchid=12465783
Old Oct 18, 2010 | 09:46 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
if your replacing your rotor - break out the BFH...
Old Oct 18, 2010 | 10:35 AM
terrasmak's Avatar
Even if you not replacing it, youj just have to be carefull with the BFH if your reusing the rotor.
Old Oct 18, 2010 | 12:51 PM
DavesZ#3's Avatar
DavesZ#3
Spray PB Blaster where the rotor meets the hub. Let it sit for a few hours then take a SFH and tap it off.
You guys noticed that this is a month old thread???
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
Beater350z
Sep 9, 2015 03:36 PM
