Any Lowering Springs That Don't Effect Ride Quality?
Old Sep 21, 2010 | 09:59 PM
TLayson23's Avatar
TLayson23
Default Any Lowering Springs That Don't Effect Ride Quality?
I just bought my '01 mustang gt for an '06 350z and one of the first things im planning is to lower it... my mustang was slammed and after 2 years of feeling every crack in the road i want to sacrifice the absolute LEAST ride quality possible. Also i only want to lower it an inch or so because i dont want to get into new caster/cambers, etc.
So, does anyone know of a good set of lowering springs that would give me a nice stance while still keeping the comfortable ride i have now? Any help is greatly appreciated.
Old Sep 21, 2010 | 10:58 PM
terrasmak's Avatar
On a sports car that is already low to the ground, going lower make its a lot worse.
Old Sep 21, 2010 | 10:59 PM
leykias's Avatar
leykias
swift sport springs.
Old Sep 23, 2010 | 09:42 AM
winchman's Avatar
winchman
Suggested custom license plate to go on lowered 350Z:
Old Sep 23, 2010 | 10:29 AM
Beau's Avatar
Beau
I didn't notice much difference when I switched to the Hotchkis TVS kit. If you get some Bilsteins or Koni's and make sure they are adjusted right you'll probably regain any ride quality you lost and maybe be better off. Shocks are mainly responsible for ride quality.
Old Sep 23, 2010 | 11:06 AM
sry110's Avatar
sry110
I'm using Hotchkis springs on OEM shocks on my 2006 350z. The ride doesn't seem to much more harsh than the OEM springs. Lowers about 5/8" front, 3/4" rear. You will be able to get aligned within OEM camber and toe specs, but naturally you will end up with more negative camber than OEM so.
NOTE: The vendor I bought the Hotchkis springs from claims that Hotchkis revised their 2003-2005 springs to be compatible with the 2006 suspension, which was revised from previous years. Other people tell me that Hotchkis never made such an adjustment. I don't know what to believe. However if I recall correctly, the spring rate on the rear Hotchkis springs is lower than that of the rear 2006 OEM springs. But please do your research and double check me.
Old Sep 23, 2010 | 11:47 AM
terrasmak's Avatar
Removing up travel from a car with little to begin with will also change the ride.
Old Sep 23, 2010 | 12:12 PM
davidc81's Avatar
davidc81
yes, they're called coilovers.
Old Sep 23, 2010 | 01:02 PM
Z_flip's Avatar
Z_flip
I believe tanabe offers them...
In fact... here... http://www.tanabe-usa.com/nf210.asp?id=2
Old Sep 23, 2010 | 01:04 PM
lgear080's Avatar
lgear080
^ I disagree. Having been in countless coiled Z's and springed Z's I would suggest
Tein H-Techs. Z's w coils are almost universally more jarring than those lowered w
any spring.
Old Sep 23, 2010 | 02:42 PM
davidc81's Avatar
davidc81
any spring.
i ride on hks hipermax rs and ride quality is almost the same as stock.
Old Sep 23, 2010 | 03:20 PM
microsteve40's Avatar
microsteve40
Know it all
I also used the Hotchkis springs for years, and they rode great. I always thought the ride quality was just about the same as stock, for what it's worth.
Old Sep 23, 2010 | 09:30 PM
lgear080's Avatar
lgear080
Cost is clearly a concern
Old Sep 23, 2010 | 10:05 PM
SuperBlack350z's Avatar
SuperBlack350z
any spring.
ive had springs before and all three of my coilover set ups were just as smooth as stock (greddy, buddy club, stance). My current Stance coilovers are actually smoother than stock and i'm slammed. sounds weird, i know.
Old Sep 24, 2010 | 12:05 AM
lgear080's Avatar
lgear080
maybe the drivers i've ridden with push the envelope harder?
Old Sep 24, 2010 | 05:16 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Sorry for some reason I thought this was NISMO...delete my previous reply
Tein S Tech are your best bet for a mild spring on a revised suspension car, such as an 06
Old Sep 24, 2010 | 05:59 AM
lgear080's Avatar
lgear080
that's the summation. somehow i missed this was for a nismo.
adam is correct as usual.
and basically has the best pricing on any item you're looking for.
I thought this for an '06 350z?
Old Oct 12, 2010 | 03:20 PM
TheDangerZone's Avatar
TheDangerZone
yeah, they offer a few differenrt stlyes of springs depending on how much a drop you want. Even then, sometimes the ride on there springs aren't as harsh as some others on the market.
Coilovers woul dbe a good choice because that way, you'll get a springs/damper that's made for each other and the ride quality will be nice. Just depends on your budget.
Old Oct 12, 2010 | 03:57 PM
Spork's Avatar
Spork
I don't get this.
Old Oct 13, 2010 | 08:01 AM
TheDangerZone
Originally Posted by Spork
I don't get this.
350Z_Al
Oct 29, 2020 07:44 PM
May 30, 2017 03:28 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
