Need Help! Stripped caliper bolt
Old Sep 27, 2010 | 06:36 PM
slitzell's Avatar
slitzell
Default Need Help! Stripped caliper bolt
My rear caliper bolt head is stripped, not the threads it bolts into. I can't get it off, and need some advice for what one would do in this situation?
Old Sep 27, 2010 | 06:41 PM
phreaktor's Avatar
phreaktor
Design Engineer
Vice Grips? Hammer an impact socket onto it? Extractor kit from Sears? I think they have one designed for lugnuts. Look in the DIY section here for a tut.
06blueZ's Avatar
06blueZ
this should do it. you tap them onto the bolt head and then as you loosen, it digs in and should let you turn it.
http://www.sears.com/shc/s/p_10153_1...=19-48530967-2
how did you strip them? were you using standard sockets on the metric bolts?
Old Sep 27, 2010 | 07:04 PM
bimmertech's Avatar
bimmertech
http://buy1.snapon.com/catalog/tools...e=snapon-store
buy any of those and you will never need another tool in your life
Old Sep 27, 2010 | 08:21 PM
cubs4worldseris's Avatar
cubs4worldseris
Ive used these before on numerous bolts while changing up my exhaust. works very well!!!
Old Sep 28, 2010 | 08:58 AM
slitzell's Avatar
slitzell
It was already too strippe to use 14mm socket on it. And I made it worse by trying vice grips.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
