increase of height after camber adj.
Old Dec 4, 2010 | 12:09 AM
JDMStanced's Avatar
JDMStanced
Default increase of height after camber adj.
i'm not looking for a precise number as it won't be possible. Stock rims and tires and stance gr+.
By eye measuring, the rear seems to have more than -3 camber. Front -2.5~-3 camber.
How much the car would raise if it get the front to -2 camber and rear to -1.2 camber?
My Z is kinda slammed for DD and want to keep it that way. So i'll drop more on top of the perfect drop i have so that when the car raises after alignment, i'll have the perfect drop again.
OFF TOPIC: Will i be able to get the rear toe in spec with SPC toe bolts after dropping the rear about 3 inches or more?
Old Dec 4, 2010 | 12:37 AM
You can plug in the numbers here:
side C is overall tire height
angle B is camber
Old Dec 4, 2010 | 10:00 AM
JDMStanced's Avatar
JDMStanced
I got front: .82mm and rear .23 mm raise. Can you confirm this?
Front from -2.5 to -2.0 and rear from -3.1 camber to -1.3
Old Dec 4, 2010 | 10:07 AM
Originally Posted by 350zRiot
Where did you get Side C? are they in inches?
http://www.1010tires.com/TireSizeCal...?action=submit
I used a 245/45WR18 tire as an example. mm just make more sense to me.
Old Dec 4, 2010 | 10:14 AM
JDMStanced's Avatar
JDMStanced
Could you confirm the number i got?
Old Dec 4, 2010 | 10:32 AM
This is making me a little dizzy because you have two tire sizes and four camber possibilities. But yes your conclusion sounds reasonable.
Old Dec 4, 2010 | 10:54 AM
terrasmak's Avatar
So you want to raise the car, get it aligned to your specs and drop it again?
Old Dec 4, 2010 | 11:28 AM
JDMStanced's Avatar
JDMStanced
i'll drop the car more than the perfect drop i have. so when the camber goes in to spec, raises the car b/c of lesser negative camber, i'll have perfect drop again.
Old Dec 4, 2010 | 12:53 PM
terrasmak's Avatar
Sorry i don't understand. Try english please.
Old Dec 4, 2010 | 01:17 PM
JDMStanced's Avatar
JDMStanced
whatever then. peace
Old Dec 4, 2010 | 01:29 PM
beezee's Avatar
beezee
I have been following your threads in the past week about your suspension install and all the problems. Looks like one pops up after the other. Keep trying. You must have very good roads to slam for DD
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
