With a Big Brake kit what do you do if you have a flat??
Old Jan 4, 2011 | 10:35 AM
RandyK1's Avatar
RandyK1
Default With a Big Brake kit what do you do if you have a flat??
I am about to order a BBK for my Z. I am trying to think a head, just in case. If I have a BBK on my Z and I have a blow out or a flat tire, what do I do. I am pretty sure that the spare tire wont fit on the car with Big Brakes. So what would I do just in case, do I have to have it towed or what?? Thanks
Old Jan 4, 2011 | 10:42 AM
terrasmak's Avatar
I need to check the spare tire from a 370Z with sport package and see if it fits. Other than that, i have roadside assistance or call a friend to bring one of my spare wheels to me.
Old Jan 4, 2011 | 10:43 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Tow it to home/shop.
Old Jan 4, 2011 | 10:51 AM
JasonZ-YA's Avatar
JasonZ-YA
Big spacers is an option....you can test and see if it works........keep one set in your car.....30mm spacers with studs, etc..
but i would lean more to tow, wait for a spare wheel, etc.....lol at daily driving with a BBK and worrying about this.........
im pretty sure this wouldn't happen to me unless i was at the track.......then i would get one of my extra 14 wheels and mount one up......but ya...
-J
Old Jan 4, 2011 | 11:04 AM
halfrice's Avatar
halfrice
usually keep one of my stock (not spare) wheels in the car with me
Old Jan 4, 2011 | 11:07 AM
terrasmak's Avatar
30mm will not clear my Wilwood 14inch kit, and Wilwood has some of the smaller calipers. I stacked a 20 and 10 for a test fit in the garage. 40mm may work, also the factory Brembo car has a different spare, that one also may work.
Old Jan 4, 2011 | 11:11 AM
Lee R's Avatar
Lee R
Brembo spare won't fit if you have upgraded discs. Found this out awhile back.
Old Jan 4, 2011 | 11:19 AM
Entaille's Avatar
Entaille
roadside assistance, large wheel spacer, fix-a-flat.. : )
Old Jan 4, 2011 | 11:21 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
triple A - free towing?
Old Jan 4, 2011 | 11:34 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Only free for a few miles, found that out quick.
Old Jan 4, 2011 | 11:36 AM
winchman's Avatar
winchman
Small 12-volt air compressor and AAA works for me. I don't like to change tires in public.
Old Jan 4, 2011 | 11:37 AM
Kwame's Avatar
Kwame
AAA Plus - Free towing for up to 100 miles @$88/year
http://www.aaany.com/membership/plus_landing/index.asp
Old Jan 4, 2011 | 11:41 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Lol ya i need to upgrade. Ive only got the standard membership so i can get their insurance...super cheap.
Old Jan 4, 2011 | 11:44 AM
Kwame's Avatar
Kwame
Just remember to tell the dispatcher that you need a flat bed and that the driver needs to bring wooden planks. I know this from experience.
Old Jan 4, 2011 | 11:49 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
I got this..!
Old Jan 4, 2011 | 11:53 AM
JCat's Avatar
JCat
OP - Excellent question.
I got a flat 150 miles from home. Not only would my spare not fit.....my lug nut wrench wouldn't either.
Old Jan 4, 2011 | 11:59 AM
JasonZ-YA's Avatar
JasonZ-YA
ebay mustang spacers are huge......will get you home....paired with brembo spare could work.....
if it was a daily car, then i guess i would take the time to figure it all out...I dont blame the OP for wanting to know..but ya, its gonna take some trial to figure it out what works for you.......there is no "simple" answer...
if you have buddies with spacers...you can try that one day, stack, measure, etc. and figure it out...
-J
Old Jan 4, 2011 | 02:26 PM
ocdz's Avatar
ocdz
I've figured it out...although it only works if the rear brakes are smaller than the front. If so, you put your rear wheel on the front and the spare in the back. It would throw off your VDC but in a pinch might get you home.
Old Jan 4, 2011 | 02:40 PM
RandyK1's Avatar
RandyK1
Good Idea, but I am also getting the rear BBK so I dont think the spare fit but it might be worth trying when I install the new BBK to know for sure. This would be for sure the cheapest option.
I also like the Brembo spare tire, I will have 2 pc rotors so maybe the spare will fit.
I do have a set of 20mm studded spacers that I should check out when the BBK gets installed also, I wonder if you can stack studded spacers
Old Jan 4, 2011 | 02:50 PM
bimmertech's Avatar
bimmertech
maybe try a spare from a GT500, same bolt pattern and they have 14" brembo's. offset might be off though, the 370 sport spare is a good idea.
i carry around a bmw M mobility sealant kit. it's a fancy fix a flat system that really doesn't work that well
