EVO-R Presents D2 Coilover suspension Kit
Old Nov 26, 2003 | 11:51 AM
  #41
GaryK's Avatar
GaryK
Originally posted by EnthuZ
Very interesting discussion!
Somewhat off topic......does anyone have a clue as to what our front split lower a-arm(or does "two piece lower upright control arms" more correctly describe it?) with 2 pivots does? I'm guessing maybe to alter the camber gain curve?
I'll take a look and see if I can give you some info on this....
Old Nov 26, 2003 | 12:02 PM
  #42
John's Avatar
John
So by those estimates, that's the equivalent to running a 900-1000lb/in spring in the rear for the "street" setup. I find that hardly streetable. I wonder if there are more factors involved...
Very good discussion though!
Old Nov 27, 2003 | 06:44 PM
  #43
JDMZ33's Avatar
JDMZ33
Vendor - Former Vendor
All D2 racing sports coilover comes with 1 year warranty. Any problem, parts will be replace within a week. If you are not comfortable with your ride either too stiff or too soft. We'll exhange with whatever setting spring you need. Just sent us your spring and will sent you the one you want.
Old Nov 28, 2003 | 07:19 AM
  #44
350z-z33's Avatar
350z-z33
Tracking the posts
Old Nov 28, 2003 | 07:17 PM
  #45
Ultimateone's Avatar
Ultimateone
PM sent Jay.
Hell I'll drive up to NY
Old Feb 1, 2004 | 06:12 PM
  #46
mchapman's Avatar
mchapman
My god you sure sound like you know your stuff!! Impressive.
Murray
Old Feb 2, 2004 | 09:07 AM
  #47
350z-z33's Avatar
350z-z33
Exclamation Snow get away!!!
Once the street here in NYC clears we'll install the D2 coil-over kit and give our feedback!!! (The weather has been terriable for the past month, snow alot and freezing temp)
Old Feb 2, 2004 | 09:46 AM
  #48
havabooz's Avatar
havabooz
do you have another set of these...i was actually thinking of getting some coilovers
Old Feb 2, 2004 | 10:13 AM
  #49
350z-z33's Avatar
350z-z33
Sorry, before we start stocking these D2 coil-over, this is the only set we have. If you are interested we can get one set for you, PM me.
Old Feb 2, 2004 | 11:25 AM
  #50
deanG35c6's Avatar
deanG35c6
So there are the numbers. It looks like the D2 is really quite stiff in the rear. I know the numbers are surprising, but this is how the math works out. I say the D2 setups will allow the car to rotate very well, maybe too well for some drivers.
So, how would the Tein Basic setup with the same spring rates front and rear fair in this comparision?
Old Feb 3, 2004 | 02:23 AM
  #51
krazy350's Avatar
krazy350
so how much are you selling those for?
Old Feb 3, 2004 | 06:43 AM
  #52
350z-z33's Avatar
350z-z33
The prices for the D2 Racing Sports Coilover suspension Kit are:
(1) $1298 without external oil reservoir/tank
(2) $1398 with external oil reservoir/tank
Old Feb 3, 2004 | 06:45 AM
  #53
350z-z33's Avatar
350z-z33
Another pic
Old Feb 3, 2004 | 07:27 AM
  #54
protocav's Avatar
protocav
with the rear springs on the shocks, would we have to worry about the tires hitting? more specifically...20X10's hitting? seems like we don't have the clearance.
Old Feb 3, 2004 | 09:09 AM
  #55
350z-z33's Avatar
350z-z33
I don't believe the rear coil-over will hit the tire/wheel, however, until we install it on the Z I'm not 100% certain. We'll take close-up pictures after it's install (hopefully this weekend, if the weather is good here in NYC). Thanks!
Old Oct 3, 2004 | 12:20 PM
  #56
GY-Z's Avatar
GY-Z
some interesting topic here.
so bump!
Old Oct 3, 2004 | 06:57 PM
  #57
PLee-Z's Avatar
PLee-Z
Wow, 15/11, sounds nice. Price? Come with camber plates at the top? I don't see how it would work.
Old Oct 3, 2004 | 08:15 PM
  #58
350Zteve's Avatar
350Zteve
Is the rear sheet metal where the upper shock goes strong enough to now have the spring there as well? There will be a lot more load in this area than when it was a shock alone?
Old Oct 3, 2004 | 11:41 PM
  #59
Gsedan35's Avatar
Gsedan35
Those can't be the Z33 D2's in the pics. I've seen pics of the D2 Z33 appilication and they use the oem location for the rear springs. And even if I'm wrong, were dipping into real murky tuning waters. I know the motion rate for the rear springs, does anyone know what the rate is at the rear shocks? http://pics.montypics.com/Gcoupe35/2...875427_z33.jpg I passed on buying them in a group buy over on NICO forums for $600 plus shipping. What stopped, besides the off brand thing was because of the spring rates and the email I got from D2. According to D2, they come with 15Kg/13Kg spring rates as the prefered rate, 13Kg/10Kg is a optional rate.
Dear Sir:
Thanks for your e-mial. Regarding your quesiton that both F-15kg/mm R-13kg/mm and F-13kg/mm R-10kg/mm are correct. For the 350Z Z33 if spring rate go for F-11kg/mm R-11kg/mm will be too soft. We will suggest you to start with the in current use spring rate, you could get this informaiton from our US distributor. And 9kg/mm can not be used on this car model.
FuBu Auto Parts Company
D2 Racing Sport Company
www.d2racingsport.com
Ok, get this, when they say the spring rate I wanted to use instead would be too soft, guess what they mean. If you try and run a spring that is softer (NOT STIFFER, but SOFTER) then their spec, it will cause the dampner to leak. One of the guys with a S14 got a little note inside his coilover box that said if he ran the extra pair of softer springs he ordered that they would cause the dampners to leak.
D2 Racing Coilovers (Monotube)
840/728 (15Kg/13Kg) F+168% R+113% (wee bit stiff eh, the recommended rate to)
Transfers 55% roll stiffness to front
Top secret and now buddy club* are the only known Z33 coilover systems running the rear springs on the dampner body. And even then the Top secret's also still run a spring in the oem location as well.
*All the spring details are not fully known at this time for the buddy clubs, but given the the spring rates they use, 748/280, all but guarantee's rear springs on the dampner body.
Frankly, ANY spring rate over 12Kg should not be considered for off track duty. The buddy clubs can be ordered revalved with softer rates.
Old Oct 4, 2004 | 07:17 AM
  #60
JDMZ33's Avatar
JDMZ33
Interesting... Then how we were able to put them on our car?
