need your help (g37 14" rotor offset vs. 350z rotor offset)
Old Jan 20, 2011 | 10:40 AM
rp_guy's Avatar
rp_guy
Default need your help (g37 14" rotor offset vs. 350z rotor offset)
hi guys,
i need the help of someone who's had these 2 rotors. i've searched but can't come to a conclusive answer.
looking at some threads, i can see that you need a bracket if you want to use g37 brakes on your 350z. what i can't see is if the caliper is offset by any amount in or out from the body.
apparently the caliper i am going for will support up to a 14" rotor, but I need to know if the offset of the disc for a 14" g37s is different from the 350z stock. the bracket was designed for a 350z rotor, which is why i need to figure this information out.
coles notes: if you lay a g37s 14" rotor next to a 350z rotor (nismo, oem), will the topmost height from the floor be the exact same amount (ie same offset from hat to disc)?
THANKS
Justin100
Nov 29, 2015 03:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
codek
Sep 28, 2015 03:03 AM
_koubie_
Sep 20, 2015 06:34 PM
