Lowering newb question
Old Feb 11, 2011 | 01:21 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I wasnt replying to the OP
Old Feb 11, 2011 | 01:41 PM
Originally Posted by redzblackh
2007 350z HR
60,000 miles
60,000 miles is about right for replacing the dampers also.
Old Feb 11, 2011 | 03:23 PM
AFG's Avatar
AFG
Originally Posted by Z1 Performance
it depends on what eibach springs
Eibach Sportlines, Sorry for not clarifying that.
Old Feb 25, 2011 | 10:52 AM
Wicked4u2c's Avatar
Wicked4u2c
I personally like these 350z Tein S Tech lowering springs -
I feel they give just the right amount of drop where the wheel is nice and tucked, and also don't rub on the fender.
Old Feb 25, 2011 | 04:01 PM
moforeynolds's Avatar
moforeynolds
At 60K you will want to change the dampers. You have to take them out anyway when you do your springs; why do the same job twice?
the front is not optional with the Sportlines, you will need new front camber arms if you want to get it within factory spec. I had SPC front and rear camber arms and rear toe bolts with my Sportlines, they had a Christmas GB that was around $500 for all. I would highly recommend you go ahead and update your dampers as well.
Old Mar 31, 2011 | 01:40 AM
AFG's Avatar
AFG
Thanks for the info, would my ride go to complete crap if i didnt get dampers?
Old Mar 31, 2011 | 01:47 AM
calin's Avatar
calin
Nobody can really say. It might, or it might not. But after 60k miles, they usually start going downhill.
Old Mar 31, 2011 | 07:55 AM
terrasmak's Avatar
Changes are that your ride is already diminished a lot from what is supposed to be, go to lowering spring will only wear out the worn out struts at a faster rate.
Old Apr 3, 2011 | 03:47 PM
n8dog11914's Avatar
n8dog11914
Not to hijack your thread OP, but I'm in a similar situation. Have about a 1.25" drop all around. My car is a 2003 with about 85000 miles on it. I do occasional autox, probably looking into the DSpecs or Konis for a new shock / strut setup as ride is harsh currently. Will daily this vehicle also. Are both of these a good call for comfort and for the track?
I'm sure an improvement over the current unrevised suspension, correct?
Thanks,
Old Apr 4, 2011 | 08:26 AM
kinethix's Avatar
kinethix
Default Lowering w/ Eibach ProKit, staying w/ stock wheels
Same question as OP.
I have a 2007 Base, with 50K-miles.
I am planning on buying Eibach ProKit, just 1" is more than enough for my taste. It is my daily use car too. I will be adding Nismo V2 Bumper in 2 weeks and I will stay with stock 18" wheels/rims.
Do I have to take additional steps when adding Eibachs, other than fixing alignment and maybe do some balancing on tires? What can I do to make the car look even when adding Nismo V2 Bumper, staying with stock tires?
Why new dampers and struts, if need it? Do I need some sway bars?
Thanks!!!
issyz
Jul 2, 2017 03:04 PM
