Lowering newb question
Old Jan 21, 2011 | 11:53 AM
redzblackh's Avatar
redzblackh
Default Lowering newb question
ok so i dont track my car and i plan on getting a front lip, so i decided on the eibach pro kit cause its only 1" drop. is there anything else i need to get. somebody told me its a must to replace the struts. idk where to find different struts for this, do i really need to? anything besides that?
Old Jan 21, 2011 | 11:57 AM
calin's Avatar
calin
Your stock struts will be good for a while until they wear out. I had my Z on lowering springs with stock struts for about 30k miles and never had a problem. You can get new ones eventually, but your stock ones should be fine for a while. One other thing you might want to consider is a camber kit since lowering the Z will give your wheels more camber and kill your tires quickly. After installing my Eibach Sportline springs, my camber was WAY off so I had to get a rear camber kit to correct that.
Old Jan 21, 2011 | 12:24 PM
redzblackh's Avatar
redzblackh
Exactly what I thought. But where do I get the new struts at? I can't find anyplace that sells them? Dino just use more stock ones? And how will I know when they DO need replaced?
Old Jan 21, 2011 | 02:35 PM
The pro kit is 4 springs. Rear is easy to replace. Front you must take apart the coil over, and replace the springs.
Old Jan 21, 2011 | 02:45 PM
RAYZ33's Avatar
RAYZ33
Check around the vendors on this forum.
From what i read; Tokico HP blues, KYB GR-2 and Bilstein B8 are all great non-adjustable replacement sport shocks that are fairly priced.
Old Jan 21, 2011 | 02:46 PM
TheDangerZone's Avatar
TheDangerZone
Tanabe is a good choice too. Those had a smooth ride. You can get shocks/struts at lot of online stores but just wait till they wear out.
Old Jan 23, 2011 | 05:39 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
1. what year car
2. How many miles
Old Jan 23, 2011 | 07:48 AM
beezee's Avatar
beezee
HP?, Better to upgrade than to replace. HPs are not the best "Upgrade"
Old Jan 23, 2011 | 07:49 AM
beezee's Avatar
beezee
Lots of good vendors here with reasonable prices. Check the Market Place
Old Jan 23, 2011 | 06:35 PM
RAYZ33's Avatar
RAYZ33
Care to share your bad experiences with em? As i said i was only giving advise to OP based on what i've read around here and so far I havn't seen that many complaints about those. Can you even consider non-adjustable replacement shocks as an upgrade?
Old Jan 23, 2011 | 10:06 PM
SDEWYS20's Avatar
SDEWYS20
Question Slammin My 06 "Z"
Getting ready to slam my z LOW got the Stance GR+ Pro Coils But i had some Questions about needing to replace other Parts Would It be A good Idea to go ahead and Buy Now Or Wait On the Front Upper Adjustable Camber Mounts And The rear Camber Arms With Rear Toe Bolts Or The Rear Camber Arms And Toe links I guess Just Need To Figure Out The Best Way To Go About Slamming My Car Down low And the Parts I Should Buy to Do So beside My Coils For A Low Stance And A Good Flush Look Thanks
Old Jan 24, 2011 | 06:34 AM
terrasmak's Avatar
If your slamming it, get a set of toe arms and 2 sets of lockouts from here http://www.350zhatchshocksandmore.com/ combines with the front camber arms and your choice of rear camber arms. The front and rear camber arms can also be gotten here http://www.nissanraceshop.com/
Old Jan 24, 2011 | 05:09 PM
SDEWYS20's Avatar
SDEWYS20
Should I put The Lockouts on The Camber Arms Also Front And Rear Or Just the Toe Arms Thanks Again
Old Jan 25, 2011 | 08:30 AM
Z1 Performance
Former Sponsor
lockout bolts have nothing to do with the front, they are for the rear..and yes, ideally you want them on both the camber and toe arms in the back
you are going to need new camber arms, new toe arms and front adjustable a arms who's bias is towards positive camber (ie SPL's) if you are looking to truly 'slam' the car and maintain any semblance of a normal alignment. SPL makes all of these parts by the way, and the quality and adjustability is fantastic on them. If you want a discounted package deal with all the components you will need, let myself or Kwame know, we can easily put it together for you
Old Jan 25, 2011 | 10:51 AM
redzblackh's Avatar
redzblackh
Originally Posted by Z1 Performance
1. what year car
2. How many miles
2007 350z HR
60,000 miles
Old Jan 25, 2011 | 11:10 AM
Z1 Performance
Former Sponsor
at 60k miles, you may want to consider new struts
a great out of the box setup would be the Tokico D Spec + Eibach rear camber and toe kit.
Old Jan 25, 2011 | 11:22 AM
terrasmak's Avatar
Great advice, so a +1 from me.
Old Feb 10, 2011 | 11:16 PM
AFG's Avatar
AFG
Let me get this clear... along with my eibach lowering springs, i need:
REAR:
1. A After market adjustable rear camber arm.
2. Rear Toe bolt
Front:
optional?
Old Feb 11, 2011 | 05:34 AM
Z1 Performance
Former Sponsor
it depends on what eibach springs
Old Feb 11, 2011 | 09:16 AM
Chako135's Avatar
Chako135
He said he had the pro kit..
