Coilover install
Old Feb 10, 2011 | 07:09 PM
User 42426's Avatar
User 42426
Default Coilover install
Hey guys,
I recently got some coilovers for the rear, and wondering how hard it would be to install it myself, just myself, no help from a friend. I have the basic tools that I always use to: take off bumper, install/reinstall headlights, take off wheels/lug nuts, stock jack. Im a diy kinda guy, but was wondering with my basic tools, and experience, how hard it would be to install the rear coils? It is oem style btw. I read some threads(diy), but they are all on spring installs, which do help, but just wondering if I should be able to do it myself with ease. Please let me know, thanks.
Old Feb 10, 2011 | 07:20 PM
AcidJake75's Avatar
AcidJake75
Living in 350Z
its cake...you need a 17mm open ended wrench (maybe 2), jack, 2 jack stands, 12mm and a somewhat long extension, wratchet too. on a scale of 1-10...i say its a 2. BUT then again ive done TONS of installs. (and thats if you run into issues)..
how does one come accross coils for the just the rears? get them cheap? Craigslist? didnt you have that bumper issue?
Old Feb 10, 2011 | 08:11 PM
AngelsVQ's Avatar
AngelsVQ
yup. hella easy. just a couple hand tools and a jack.
Old Feb 10, 2011 | 09:07 PM
User 42426's Avatar
User 42426
^^Yea, cheap coils on craiglist. hks ls coils for just the rear. I don't think I need to drop the front, as the new bumper is pretty low.
Old Feb 11, 2011 | 09:55 AM
User 42426's Avatar
User 42426
can i just use the stock jack? or do I need a different jack and jack stands? I was thinking of just using the stock jack and working from that...
Old Feb 11, 2011 | 10:17 AM
terrasmak's Avatar
Yes, but NO. Be a man, buy proper tools, earn your mancard, do your own installs and save big $$$$$
Old Feb 11, 2011 | 10:36 AM
JDM555's Avatar
JDM555
The install isn't hard. It may take some time if you're doing it solo. Not to mention you might run into some stubborn *** bolts like I did. Make sure you have a breaker bar for the rear bolts. PB Blaster will help a lot too. The rear are easier than the fronts btw.
Old Feb 12, 2011 | 04:20 PM
User 42426's Avatar
User 42426
one last question. I bought the hks ls coils for the rear, and the height is adjusted by the spring perch. I turn it up or down to adjust height. Does that perch replace the stock spring mount? Do i not need the spring mount anymore? And how hard is it to adjust height with that? Do I need to take off my wheel everytime I want to adjust the height? Just imagining it, it would seem hard to stick my hand in there to adjust it with the wheel on. Just asking before I install them, cuz if thats the case, I don't want to mess with that later on and might just sell them, thanks.
Old Feb 12, 2011 | 04:28 PM
User 42426's Avatar
User 42426
^^btw, also, I saw the thread of 350z actual coilovers, and some oem style coils had hats. And they go under the spring, on the spring bucket. I don't have those. i only got the rear springs with spring silencers, spring perch, and strut. Is that all I need? Also, the spring silencer goes on top right? Not on the bottom touching the spring bucket but touching the spring perch? Sorry for the noobness, first time installing/coils. And getting installation instructions or even seeings pics of the hks ls is hard. Thanks.
Old Feb 12, 2011 | 04:33 PM
erichsherrill's Avatar
erichsherrill
tip- spray PB blaster the day before u do the install
Old Feb 12, 2011 | 04:35 PM
User 42426's Avatar
User 42426
^^+1 on that, head that tip many times. Thanks!
User 42426's Avatar
User 42426
btw, i didnt get any new screws or nuts, would it be okay to re use the stock ones?
Old Feb 12, 2011 | 04:49 PM
erichsherrill
^ ya mon
Old Feb 12, 2011 | 05:37 PM
AngelsVQ's Avatar
AngelsVQ
mancard
never travel withought it
Old Feb 14, 2011 | 07:01 AM
GuardDrgn86's Avatar
GuardDrgn86
Is this what the coils look like OP?
Old Feb 14, 2011 | 04:41 PM
User 42426's Avatar
User 42426
^^yea they do. THanks for the pic, that helps a lot. Do you see the hat on the bottom left, that goes on top of the spring and REPLACES the stock rubber spring mount, correct? And the spring silencers are already installed on the spring, and they touch the hat, not the spring bucket, correct? Just want to confirm these little things before installing myself.
Old Feb 15, 2011 | 07:00 AM
GuardDrgn86
Correct, the spring hat replaces the rubber upper spring mount and retains the lower rubber spring seat. The spring orientation has the spring silencers seated to the spring hat so it sounds like you are good to go on the install. Be sure to upload some pictures after you're done.
Old Feb 15, 2011 | 08:13 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
you wont get very far with the OEM jack.
You have to have both wheels in the air to remove the struts. The sway bar will fight you the whole way if you don't. I also wouldn't recommend the OEM jack for safety reasons.
Old Feb 15, 2011 | 09:49 AM
User 42426's Avatar
User 42426
Thanks a lot for confirming. I can finally get to work now :]
Old Feb 15, 2011 | 09:51 AM
User 42426's Avatar
User 42426
I know the stock jack isn't that great, but im only removing the rear suspension. I saw diy threads, and they didnt mention anything about the sway bar or lifting both wheels. I'm only doind the rears and jacks stands and a stock jack seem sufficient.
