Few questions on the KW var3 coilovers
Old Mar 2, 2011 | 06:57 PM
GT4Zed's Avatar
GT4Zed
Default Few questions on the KW var3 coilovers
I have the KW variant 3s coilovers which are absolutely very good quality and performance and i'm hooked but want to go for the true rear coilover setup.
I saw this pic on Jason's informative thread and was just wondering if KW make a true rear coilover for the 350z? look so
If there is no such system for the 350z i would like to upgrade my var 3 front and rear springs to linear springs as opposed to progressive KW OEM ones. I figure it should not be a problem if i get the sizes(height/diameters) right and specify the same max spring rate as the original. The damper should be able to handle it right?
For the rear i would go for the 2.5" ID spring so it can fit the SPL midlink to give me the next best solution to the true rear coil setup.
I will be calling or emailing KW do see if the can provide these or go with swift springs.
In effect i will be upgrading my Var 3 s to clubsport
Any thoughts on this or any pitfalls i have missed?
Old Mar 3, 2011 | 01:41 PM
klenkart's Avatar
klenkart
Im pretty sure the kw clubsport is a true coilover
Old Mar 11, 2011 | 02:37 AM
scoobyrex247's Avatar
scoobyrex247
the shocks are valved for their intended progressive spring rate. I wouldn't mess with linear springs because then you'd have to get the struts re-valved. At that point, might as well purchase "true style" club sports because of all of the R and D that went into them would surely surpass the common enthusiasts' know how.
Old Mar 11, 2011 | 10:17 AM
Chebosto's Avatar
Chebosto
unless they switched their design. the club sport still have the spring bucket.
Old Mar 11, 2011 | 10:45 AM
Voboy's Avatar
Voboy
KW Clubsport rear shocks convert the 350Z to coilovers instead of the stock system that has a separate spring and shock. This saves a bunch of weight.
http://www.motoiq.com/magazine_artic...tack-350z.aspx
