compression arm
Old Mar 10, 2011 | 03:08 AM
tw8715's Avatar
tw8715
Default compression arm
so i need a new compression arm cause mine is bent.
new one is 190 shipped and a used one on ebay is 115 shipped.
which one should i go for?
used one has 40k miles on it and is from a 2006. garunteed to be striaght too.
asking cause not sure about used oem suspension parts.
thanks!
Old Mar 10, 2011 | 07:53 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
guaranteed straight is all well and good, but the bushings are equally important, and at 40k, its anyones guess
no brainer answer IMHO. With one you're good for at least another 40k miles - with the other, who knows
Old Mar 10, 2011 | 08:08 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
which side?
I have a passenger side compression arm with a busted bushing I would sell for well under 115 shipped.
Threads's Avatar
Be weary if you are purchasing the cone bushings as well (ball-joint side). There are 3 different ones IIRC. I recently purchased new arms and I believe i got the wrong version(year) bushings. The bushings do not sit properly on the ball-joint stud which causes problems securing the arm to the hub.
Old Mar 10, 2011 | 08:32 AM
tw8715's Avatar
tw8715
oh really? very interesting.
i was going to purchase from here.
http://www.conceptzperformance.com/C...98.117.143.105
it says newest bushings which last longer. it seems like there is no year for ordering.
any input?
Old Mar 10, 2011 | 09:16 AM
Threads's Avatar
any input?
I believe that website is referring to the bushing on the non ball-joint side. The new arms do not come with the cone bushings (in my case at least) that sit on the ball-joint stud. You may be able to reuse the ones on your stock arms by removing them with a puller. I was unfortunate and had to order new ones. If you are unclear about the cone bushings, take a look at a parts diagram/image.
Old Mar 11, 2011 | 06:41 AM
tw8715's Avatar
tw8715
sounds good.. just ordered a new one
i was wondering if a 1 degree bent arm would be visible to the eye? even when comparing to a brand new arm?
thanks
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
CJs_Z33
Sep 18, 2015 12:06 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
