Just finished my 06 brake upgrade, 03-05 guys lookie!
Old Mar 29, 2011 | 05:46 AM
  #41
Voboy's Avatar
Voboy
^- Those 06 G brakes are the same as the 06-08 Z Non-Brembo's.
Old Mar 29, 2011 | 05:55 AM
  #42
e30cabrio's Avatar
e30cabrio
I'm really glad you are happy with the calipers/pads!
Old May 11, 2011 | 08:18 PM
  #43
Z33LOS's Avatar
Z33LOS
This is EXACTLY what I was looking for! I'm about to pick up a set of 06 calipers and was wondering how this swap would go n now I know! I jus gotta make sure that they have the brackets to go along w/ the calipers. If not can I jus go to the stealership n order them? Thanks Op for this post.
Old Sep 3, 2011 | 03:07 PM
  #44
joepro's Avatar
joepro
and update on the paint, 3 of 4 calipers is still perfect, on has a few small digs in the paint which I have not decided how to fix yet, I was disappointed to see the chips but something clearly hit it pretty good because none of the others have chipped.
Old Sep 4, 2011 | 01:08 PM
  #45
neverseen's Avatar
neverseen
I picked up a set of the 06 calipers a while back. Time for me to do a break job now so I figure i'll go ahead and upgrade. The car only gets about 4,000 miles a year of back and forth to work so I'm comfortable using ebay rotors. I could not locate the seller you mentioned. Do you have a link by chance? Also, if I find out I do not have the bracket i need (i know i don't have it for the rear) where am I able to buy one of these from?
Old Sep 4, 2011 | 01:21 PM
  #46
e30cabrio's Avatar
e30cabrio
I sold the op his calipers and still have the EBC slotted rotors I used with them. I'll let them go for 300 shipped. They are in this thread:
https://my350z.com/forum/south-west/...ed-rotors.html
Old Sep 4, 2011 | 03:16 PM
  #47
neverseen's Avatar
neverseen
the part numbers in the picture come up as the full assembly. is there a source on just the bracket needed for the rear brakes, or will i need to find a used set to take it off of?
Old Sep 4, 2011 | 05:20 PM
  #48
joepro's Avatar
joepro
not sure about nissan(I work for honda) but you cannot get the bracket separately, either used or in a junk yard maybe?
http://cgi.ebay.com/ebaymotors/NISSA...ht_1877wt_1165
Old Sep 4, 2011 | 09:08 PM
  #49
JDMStanced's Avatar
JDMStanced
Is it even worth it to change out the rear? The difference in rotor size isn't that much..
Old Sep 13, 2011 | 08:47 AM
  #50
itremillo's Avatar
itremillo
well if you can get all four calipers front an rear for a good price, i say just change all 4. i had the 04 brake set up with one piston on front. i found a guy selling his 06 350z brakes, lines, caliper, rotors and pads with only 12k miles and asked for $150 swap went very smooth, took me about 4 after bleeding and all. performs similar to the brembo brakes.
Old Sep 21, 2011 | 04:18 PM
  #51
DJADL's Avatar
DJADL
Did you have to get new lines for the brakes? or were you able to reuse yours?
Old Sep 21, 2011 | 05:41 PM
  #52
Bmurray350z's Avatar
Bmurray350z
Looks good
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
samansharif
Sep 25, 2015 12:31 PM
