View Poll Results: What front camber arms do you have?
Megan Racing
6.67%
SPL
26.67%
SPC
24.44%
Ichiba
6.67%
Kinetix
20.00%
other
15.56%
Voters: 45. You may not vote on this poll
If your LOW and have aftermarket front UCA's look here!
Old Mar 26, 2011 | 06:16 PM
PAYBACK's Avatar
PAYBACK
Default If your LOW and have aftermarket front UCA's look here!
If your car is slammed and you've replaced your front upper control arms to adjust camber what arms do you have and are you bottoming out (UCA hitting the top of the chassis / body) I'm not here to get roasted for buying cheap parts I just need to know what arms will work for my car. I'm low as hell and have Megan camber arms and they are hitting the body even with my coils are as stiff as possible. I want to run SPC's but the design doesn’t look to much smaller than Megan so I'm thinking about SPL arms (look like they have the most slender design but also pricey) I came across some Kinetix arms but they look downright weird...thanks in advance for any feedback
Old Mar 26, 2011 | 06:55 PM
PAYBACK's Avatar
PAYBACK
Looks like I'm gonna have to take the royal_T approch and cut some ****! seems like everyone thats really low is hitting no matter what arms they have but I think I'm still gona ditch the megan arms and buy SPL's anyway
Old Mar 26, 2011 | 09:02 PM
terrasmak's Avatar
Megan arms are very thin compared to spc, they are real low profile.
Old Mar 26, 2011 | 10:20 PM
PAYBACK's Avatar
PAYBACK
Its not really the thickness of the arms its the length in the adjustable flange that is causing the problem
Old Mar 26, 2011 | 11:28 PM
kramykram's Avatar
kramykram
even with the v1 spl i bottomed out. best bet is to pull your coilovers apart and put a bump stop in their. that or what i was originaly trying to do and cut the spots in the frame where they were bottoming out. i have a ton of stuff cut under my fender well from when i was 2" from the ground.
Old Mar 27, 2011 | 12:32 AM
terrasmak's Avatar
I had to trim the plastic fender liner slightly, other than that it bottems out on the inner fender like any other UCA. But the Megan arm is thinner than most. arms.
Old Mar 27, 2011 | 09:24 AM
PAYBACK's Avatar
PAYBACK
I'm looking at the v3 spl its a completely different design. Thanks for your input though
Old Mar 27, 2011 | 09:27 AM
phreaktor's Avatar
phreaktor
Design Engineer
Let me know via PM if you are going to sell the Megan arms for a decent price.
Old Mar 27, 2011 | 01:11 PM
PAYBACK's Avatar
PAYBACK
For sure! they have 10 miles on em haha Ill let you know when they are off
Old Mar 28, 2011 | 06:42 AM
no vtec 4me's Avatar
no vtec 4me
Im running spc/eibach's and they hit like a ****. Im going to try the stock ones on tonight (Will put my camber around -2.75 which isnt HORRIBLE) and see if the bottoming out stops. If it doesnt im taking it to a local fab shop to have my inner fenders all hacked up. Im pretty low but want to be DUMPED and cant stand the bottomoing out anymore.
Old Mar 28, 2011 | 08:27 AM
terrasmak's Avatar
I wonder if people understand that bottoming out is just part of being low. Its not like you can magically gain a bunch more suspension up travel, and if you could, the common fool would probably just lower car more to get rid of the extra up travel.
Old Mar 28, 2011 | 10:13 AM
no vtec 4me
bottoming out doesnt have to be part of being low. My stance coilovers arent going to bottom out on me, i know that. Sometimes you have to cut/weld/grind, but where theres a will, theres a way, and im not going to raise my car just because something is hitting. Ill just make room.
Old Mar 28, 2011 | 11:31 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
to the OP - what exactly are you trying to achieve?
what is your rideheight (distance from level ground to centerline of front fender)?
as far as bottoming out, you have to define that - suspension (strut/spring/coilover) or your a arm hitting your inner fender? Two totally different things
Old Mar 28, 2011 | 01:41 PM
PAYBACK's Avatar
PAYBACK
ground to fender is around 24.5 I want to bring it to 24.25 or 24 the only thing bottoming out is the a-arm hitting the inner fender...
Old Mar 28, 2011 | 05:23 PM
350Z_Al's Avatar
350Z_Al
Smaller tires
Old Mar 28, 2011 | 08:47 PM
JDMStanced's Avatar
JDMStanced
why not get kinetix arms and be able to match left and right camber?
Can you go lower with stock arms as far as hitting the well?
Old Mar 29, 2011 | 02:51 PM
no vtec 4me
I have spc camber arms...i can adjust camber up front. Its just that they hit the inner fender. I dont know if i can go lower or not by putting the stock arms in or not, but will find out one of these nights. If not, im no stranger to hacking up my car to go lower so some nice cutting could be happening in the near future.
*and when i say hacking up i mean done professionally, clean and correctly.
Old Mar 29, 2011 | 02:58 PM
JDMStanced's Avatar
JDMStanced
I have SPC arms too. The car is not crazy low but my arms do bottom out often. I doubt you can go lower with SPC unless you mod the side of arms or cut the whole inner fender lol
Ima switch out to Kinetix.
Old Jan 9, 2014 | 11:07 AM
Trevor Hebert's Avatar
Trevor Hebert
If you guys stayed with the SPC arms, and cut up the fender a bit, how did it go?
Was the clunking reduced a lot?
Did it mess anything up?
Sorry for the questions, this clunking is killing me.
Old Jan 9, 2014 | 09:25 PM
AARONHL's Avatar
AARONHL
Kinetix arms are so underrated
