370z brakes on a 350z?
sorry if this topic has already been discussed. looking to upgrade my calipers and was wondering if the 370's will fit the 04 350z (non-brembo of course)?
thanks in advance
rw
thanks in advance
rw
awesome...very reasonably priced kits...and they look great! if i hadn't already had the stoptech stage 2 these would be the kits i would look into for sure. i only need the calipers...in black...already have the rotors and steel braided lines. gonna go with black...if they sell them seperately.
that will definitely be my next mod
hmmmm...might have to reconsider. actually, the stoptech stage II kit is working very well for me. i don't track and i my z is a daily driver. i've got great stopping power as is right now for my needs.
i thought maybe just the 370z calipers would be a nice upgrade...but if they won't work with what i have, or the stock rotors, i will have to pass.l
Bigger rotor = more heat capacity to resist brake fade due to pad overtemperature (as you might experience on a track) and helps resist brake fluid boiling as well
Bigger caliper supposedly = stiffer, more heat capacity here too
Better caliper design = easier to change pads
More pistons = more even pressure distribution on pads resulting hopefully in more even pad wear, beyond a certain point increasing # of pistons (pots) is mostly for show
More rotational mass = worse handling, worse acceleration
