front Toe spec
Old Apr 5, 2011 | 07:03 PM
JDMStanced's Avatar
JDMStanced
Default front Toe spec
Hi,
I need help with front toe spec quickly.
I'm replacing my SPC arms with stock arms. If the camber stays around -2.7, i'll stick with stock arms. So my question is, If the camber is around -2.7, what would be the wise number for toe spec for reducing the wear on inner side of tires, AND for DD and autox use? i expect some wear on inner side of tires, but was told that good number in toe will save it.
My car is dropped with Stance gr+ by the way.
thanks in advance
Old Apr 5, 2011 | 09:05 PM
terrasmak's Avatar
Normally 1/16 toe out for track and autocross, but since my Z is a daily driver i use a hair of toe in up front.
Old Apr 5, 2011 | 09:22 PM
JDMStanced's Avatar
JDMStanced
i was told that if you have some negative camber (-2.7), it'd be best to go as close to zero as possible. maybe 0.00 to 0.05. Is that right?
Old Apr 5, 2011 | 10:35 PM
terrasmak's Avatar
Thats what i run, my last alignment was 0.03 toe in. Did you raise your car yet?
Old Apr 6, 2011 | 08:09 AM
JDMStanced's Avatar
JDMStanced
i'm not raising my car. I found a guy who had SPC but swapped to stock arms. (prolly lowered than i am) No more riding on bumpstops and rides like a champ. -2.7 camber will lower my car little, so i'm HAPPY
Old Apr 8, 2011 | 01:19 AM
JDMStanced's Avatar
JDMStanced
i swapped to stock arms. NO running on bumpstops! wow. It feels so nice to make a fast bumpy roundabout without running on bumpstops lol
If i get the alignment done, will i get more negative than now? It looks like there's not even -2.0 camber -_-...i wanted like -2.5
Old Apr 8, 2011 | 07:56 AM
terrasmak's Avatar
Nope, you can't adjust camber up front without adjustable arms.
Old Apr 8, 2011 | 08:08 AM
JDMStanced's Avatar
JDMStanced
i know. i meant like assuming that i have toe out now (misalignment), if i get the toe close to 0 or toe in, will it give me more negative camber?
Obadabot
Jun 18, 2023 11:31 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
