How do nf210s feel
Old Apr 7, 2011 | 06:44 AM
bjjbadboy's Avatar
bjjbadboy
Default How do nf210s feel
Hey guys I have threads up here about springs not getting to many replys so I changed uP my question hopefully have some better feed back.
Will I rub up front with tanabe nf210s? There is only a 5% increase in spring rate so I am affriad that with 19" rims (245/35/19) up front that if i hit a dip on the highway I'm going to rub like crazy.
Can anyone have any input to this? I would like to add some grip with the lowering springs but keep it stock feeling also. Hence my choice of nf.
If I am going to have problems my second choice is the gf210 I have only read about 1 guy not liking these. They have a high spring rate then the nf series and only a 1" drop up front so guessing rubbing won't be a problem. I would just go right out with these ones except if I could get an extra .2 up front too I want it lol and they r supposed to be gripper so I'm guess I little stiffer ride even though most members said rode very close to stock. Guess just wanna compare feel of both I have seen 1000pics and searched every forum I could find.
Thanks in advance
If I'm right that
Old Apr 7, 2011 | 07:12 AM
terrasmak's Avatar
If you bought wheels with the proper offset, you have the proper height tire , you will not rub when the car bottems out the suspension.
Old Apr 7, 2011 | 07:44 AM
bjjbadboy's Avatar
bjjbadboy
Thanks very much. I believe my front wheels are proper set up forgot the offsets but they sit perfect in the fender almost line up with it but still little tucked as for size I bought rims and tires used when my stocks were done for a great deal I have seen alot of members running 245/35/19 up front I know I need more tire in the rear to fill up the gap but like said they were used when there donzo I'll get the right rear tires. They r 295/25/20.
Can anyone add the way the ride feels comparing the gf's and the nf's
Thanks again in advance as always
Old Apr 7, 2011 | 04:00 PM
dvo's Avatar
dvo
I had Tanabe NF210 springs before and they rode great. no complaints
Old Apr 12, 2011 | 11:45 AM
bjjbadboy's Avatar
bjjbadboy
ended up going with the gf210 for now hoping I mad the right choice.... went with the slightly stiffer set up after reading post that the spring rate should be stiffer to make up for the 1" difference...
Old Apr 13, 2011 | 12:00 PM
Junkster's Avatar
Junkster
I have NF210's and i like them...i prefer Coilovers but i bought my car with these on and its alot better than stock (from what i have experienced).
I think you will be perfectly fine, the spring rate increase of 5% isnt going to make or break any rubbing issues u might have. It is somewhat of a moot point if you ask me...
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Jambo016
Sep 16, 2016 01:08 PM
James1990
Dec 16, 2015 08:57 PM
Tochigi_236
Sep 27, 2015 03:40 PM
