wilwood bbk
Old Apr 11, 2011 | 07:27 AM
styy81's Avatar
styy81
Default wilwood bbk
hi bros,
any feedbacks on wilwood 6pot 355mm F/ 4 pot 330 mm R?
Hows the performance compare to stoptech?
i am thinking of getting either one of this bbk set still cant decide yet.
thanks.
Old Apr 11, 2011 | 07:46 AM
styy81's Avatar
styy81
my apology for duplicate posting, mod pls assist to remove.
Old Apr 11, 2011 | 07:57 AM
plumpzz's Avatar
plumpzz
Its good at stopping but its noisier than a stoptech bbk due to the design. However, the change parts are far cheaper than stoptech and the brakes will stop just as good.
Old Apr 11, 2011 | 09:23 AM
terrasmak's Avatar
Never driven on Stoptechs, but have had no problem with my Wilwood kit. For heavy track use i suggest buying the front set with the W6A caliper, but i track the hell out of my car with the Bsl6 caliper no problem.
Contact Todd at TCE for best info about Wilwood systems.
Old Apr 11, 2011 | 09:27 AM
plumpzz's Avatar
plumpzz
^+1. The W6A caliper won't be as noisy as the BSL6. That caliper is directly comparable to the stoptech calipers (non competition).
Old Apr 11, 2011 | 09:43 AM
terrasmak's Avatar
Mine arn't noisy, once an a while with street pads you need to file the top edge of the pad, if you do that, no noise. I do it every time i pad swap to race pads.
Also race pads are cheap for wilwood , i ran Poly B pads for 3 years $130 a set, and just moved over to Poly E? can't remember $190 a set. Rears are even cheaper, and street pads are slightly over $60.
Old Apr 11, 2011 | 10:08 AM
plumpzz's Avatar
plumpzz
A common problem with the Sl6 is creaking sounds from flex. Reshimming them helps but youll always get flex. Ive contacted wilwood and they confirmed the problem, but said since the piece is billet the flex does not affect function.
Pads will be noisy, especially since I run the polyE pads. I heard the BP10s are much quieter but I havnt tried them out yet.
Old Apr 11, 2011 | 11:59 AM
terrasmak's Avatar
Poly E , race pad, Same with Poly B, i highly doubt any full fledge race pad on the market is quiet.
Old Apr 12, 2011 | 05:37 AM
Todd TCE's Avatar
Todd TCE
TCE Performance Products
The W6A caliper is much larger, beefier and has a bigger (about 15%) pad for longer wear and an increase in surface area making them more stable. This caliper is available as a alternate of sorts to the factory 14" kits but cost much more due to the cost of the caliper, pads and custom TCE brackets. And sadly this substitution cannot be made as a 'kit' purchase but must be assembled piece by piece for production. (making it a TCE kit, not a factory Wilwood kit)
For track use the B pads are a great starting point. For those with better tires, more experience and the desire to push harder a move to H or even A pads is very doable but comes with a greater wear rate and noise. E pads being a good intermediate pad but fully metallic thus a bit more noise. A combo of H front and E rear would be quite nice on track and if one thinks they could still yet get more from the rear: H/B. Pads remain like tires however....subject to a lot of personal taste.
Old Apr 16, 2011 | 07:41 AM
styy81's Avatar
styy81
Thanks for the feedbacks. By the way if given a choice will I go for stoptech or
Wilwood?
Old Apr 18, 2011 | 08:49 AM
Alexl08's Avatar
Alexl08
Wouldn't waste my money on wilwood
Old Apr 18, 2011 | 10:29 AM
MUZZY's Avatar
MUZZY
I have called wilwood several times, they are misin the hats for theFront kit, been 1 month now and no ETA till 60days from now. th wait for a # of orders before they even start making the part. so there is a 90 day delay on them if that changes your mind
Old Apr 19, 2011 | 04:24 AM
Alexl08's Avatar
Alexl08
If you guys want some function over form just go with a PFC BBK that what my car is getting although I use it on the track not street
Old Apr 19, 2011 | 12:08 PM
BoomerZ33's Avatar
BoomerZ33
Wilwood?
Wilwood. i know more time attack guys using and trusting wilwoods than stoptechs
Old Apr 19, 2011 | 02:47 PM
terrasmak's Avatar
There is a really good mix of brakes in the paddock.
Old Apr 19, 2011 | 06:16 PM
Alexl08's Avatar
Alexl08
Goto a grandam event or amls and see if you see any wilwood stuff you wont cuz wilwood is junk. PFC/Brembo/AP/Stoptech
Old Apr 20, 2011 | 02:04 PM
Todd TCE's Avatar
Todd TCE
With that logic you could go to hundreds more weekly circle tracks; sprint cars, midgets and modifys many running Wilwoods...so all those others are junk. Never mind that as a NC resident you may well work for that PFC shop and thus haven gotten a great deal to pass along this info?? Just a thought. I could be wrong of course.
Reality is none of them are junk. Some are just far more costly than others and while the merits of one design over the other can be argued the average consumer couldn't tell a Apembo from a Stop-Con or a Alwood. If you're running an endurance race the main element is pad thickness. I don't know to many street enthusiasts needing 1.10" wide pads and the shoebox size calipers that go with them. Nor the need for that large a wheel spacer.
FWIW, a couple of the b/o Wilwood kit are in process and on the way. There was no "waiting for a bunch of orders..." there were simply more sold then expected and to some degree a lull in forecasting of sales for the Spring that have effected a vast number of product. But they're doling out the OT and guys are in fact working (something we don't hear a lot of so hat's off to Wilwood) to get the inventory back up.
Trust me...I probably know better than most of you.
Old Apr 21, 2011 | 05:09 AM
Alexl08's Avatar
Alexl08
Yeah because a brake caliper with zero drag means nothing in racing. Also even pressure distribution and mulipad means nothing as well. PFC brakes are far more superior then wilwood. Wilwood calipers are poorly made along with their china disc. My Front calipers weigh in at 6.5 lbs and they fit a massive disc. Also PFC make every brake package from the ground up, they engineer the brake kit for the specific car and determine the proper balance for the cars current setup. But dont take my word for it. Ask Billy Johnson or Jack Roush JR or James Clay the owner of Bimmer world who run them in grand am. My point is that alot of missed information is looked over. The idea behind a BBK is to increase your thermal capacity not how big it is or number of pistons its who can run the coolest thus letting you use your brakes longer and PFC has been the best of the best at doing so example their 1st and 2nd place finish in the 24hrs of Daytona race.
Old Apr 21, 2011 | 06:32 AM
plumpzz's Avatar
plumpzz
Are you getting paid to troll here?
Old Apr 21, 2011 | 07:30 AM
Alexl08's Avatar
Alexl08
lol nope I dont know why people get mad at the facts
