Will a 0 offset rub in front!?!?
Old Apr 29, 2011 | 02:58 PM
WFjGer's Avatar
WFjGer
Default Will a 0 offset rub in front!?!?
I'm pretty new to this so don't kill me for asking this question. Thanks
I plan on running wheels with a Zero offset in the front of my car with 18x9.5 inch wheels wrapped in 255/40 tires. Will I rub with this low offset? And if so what do I need to do to prevent from rubbing?
Old Apr 29, 2011 | 03:00 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Apr 29, 2011 | 03:13 PM
bimmertech's Avatar
bimmertech
you will not rub, it will be much worse than that.
the obvious solution would be to not put those poor fitting wheels on in the first place. the ricer solution would be to keep adding negative camber until it clears--which it most likely won't. then you will have to put on a really narrow tire to get it to not rub.
Old Apr 29, 2011 | 03:46 PM
TheDangerZone's Avatar
TheDangerZone
That'll fit with room to spare.... put it on and drive it around and post pics after
Old Apr 29, 2011 | 04:25 PM
terrasmak's Avatar
Close to -3 camber and it will work
Last edited by terrasmak; May 1, 2011 at 12:31 AM. Reason: Dam phone changed camber to camper
Old Apr 29, 2011 | 04:44 PM
KingBaby's Avatar
KingBaby
Hardest Setting
If I where a mod!
This **** would be locked so fast you wouldnt be able to slide in. The Op would be pm with links to where info could be found
I'd give out a months premier if you could slide in before the lock
Old Apr 30, 2011 | 06:51 PM
WFjGer's Avatar
WFjGer
Ok so it will or will not fit ?
Old Apr 30, 2011 | 06:55 PM
r_seng's Avatar
r_seng
No rub no love. Don't be a b*tch!
Old May 10, 2011 | 06:50 PM
jbrizz94's Avatar
jbrizz94
you'll be fine, i have 0 up front and low with no problems
Old May 11, 2011 | 09:27 AM
scrantonz33's Avatar
scrantonz33
Pics?
Old May 11, 2011 | 12:01 PM
beezee's Avatar
beezee
Are you lowered?
Old May 26, 2011 | 10:08 PM
jdm94589's Avatar
jdm94589
It will fit,I run 245 45 18 though.Also I got front camber arms so no rub at all
Old May 26, 2011 | 11:40 PM
marques1's Avatar
marques1
0 offset in front and rear. I'm running a stretch though 225/35 up front. my front wheels are 9inches wide to your 8.5 just to give you a idea. no rubbing issues but i did have to get the rears rolled they rubbed alot.
Old May 27, 2011 | 03:50 AM
midz350's Avatar
midz350
Wheels question in the brakes & suspension forum!!!
IBTM.
Old May 27, 2011 | 06:20 AM
Z04's Avatar
Z04
do you even know what wheel offset is? if you did then you could answer your own question. best way to not rub? get proper fitting wheels for your car
Old May 27, 2011 | 02:49 PM
TheDangerZone
you can make it fit.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
