Nismo S-Tune suspension question
Old Dec 4, 2003 | 05:46 AM
jmark's Avatar
jmark
Question Nismo S-Tune suspension question
I have heard from sources the S-Tune suspension fixes the feathering problem inherent in the 350Z. The alignment must be correct of course. I know Droid had problems cause of improper alignment. Anyone else have problems after the S-Tune is installed? The only thing I can think is the S-Tune shock/progressive spring package which fixes the bounce must also eliminate the feathering (caused by bad shocks?). Opinions. I am considering the S-Tune because I am hearing NNA will look to see what's installed (IE aftermarket shocks etc.) and can cause warranty issues as far as the feathering of the tires.
Old Dec 4, 2003 | 07:51 AM
fdao's Avatar
fdao
Default Re: Nismo S-Tune suspension question
Jmark,
I have the S-Tune. I wouldn't say it fixes the bounce completely. I still feel it. Sometimes just as pronounced as stock, other times less. When I had my alignment done, everything was within specs. I had the tech set my Toe-in at max allowable range, 2mm.
Old Dec 4, 2003 | 12:33 PM
jmark's Avatar
jmark
Other opinions.
Old Dec 4, 2003 | 05:48 PM
TCL's Avatar
TCL
I'm betting that the final answer to the feathering issue will be clear before the Koni shocks are available (my planned upgrade). The suspension modifications options will easier to sort out at that point.
I stopped following the feathering threads closely since they're all over the map in terms of possible causes and solutions (and because it hasn't been a problem for my car yet). I check them occasionally to see if the "official" definitive answer has been put forth.
Old Dec 4, 2003 | 05:57 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Jeff said he hasnt had any problems with feathering...
well see if i do when I put it on mine... My tires are feathered more then you would believe. I put over 2000 miles on my car a month.
Old Dec 4, 2003 | 09:35 PM
SHO-TIME's Avatar
SHO-TIME
I'm getting my S-Tune installed this weekend. I'll post my review then....
(But I dont have the feathering problem with my stocks suspension though.)
Old Dec 5, 2003 | 04:20 AM
jmark's Avatar
jmark
You are probably right TCL.
Old Dec 5, 2003 | 04:21 AM
jmark's Avatar
jmark
Cool. Looking forward to the review. Is Performance during the install?
Old Dec 5, 2003 | 07:58 AM
SHO-TIME's Avatar
SHO-TIME
Yes, Performance Nissan is doing the install as we speak.
Old Dec 5, 2003 | 08:23 AM
jmark's Avatar
jmark
Let me hear the results ASAP. Do you have the bounce?
Old Dec 5, 2003 | 08:28 AM
KJY9's Avatar
KJY9
I just ordered mine this morning and install will follow as soon as they arrive. My Cuso sways should be here today, hoping to get a good mix out of the two.
Old Dec 5, 2003 | 08:40 AM
jmark's Avatar
jmark
KJY9,
Do you have the bounce currently?
Old Dec 5, 2003 | 09:00 AM
SHO-TIME's Avatar
SHO-TIME
I do have the bounce rite now, especially on the HWYs. We'll see if that gets eliminated after the install.
Old Dec 5, 2003 | 09:41 AM
KJY9's Avatar
KJY9
KJY9,
Nope...not a hint of it..I'm not doing my suspension mods to correct "the bounce".....just tightening up the suspension a bit for the track this spring. It's my daily driver so I don't want to get too radical with it
Old Dec 5, 2003 | 06:56 PM
Gsedan35's Avatar
Gsedan35
Here's a already posted review from a owner that would have come up running a search on nismo S-tune suspension. Originally posted 07-03-03 by droideka Take note that the front springs are NOT progressive, only the rears are.
Originally posted by droideka
Full NISMO Suspension w/sways, Stock 18s, WORN OUT S-03s
One week after the HPDE, I had my suspension installed. I'm running on the stock 18s so I can save my new rear tires on the Track wheels until I replace the fronts. First things first. IMO, the "bounce" has been eliminated. I was an early objector to the bounce in the stock suspension and described is as an "echo" bounce that continued after the intial impact for a couple of seconds. It is my belief this has been cured simply by reversing the spring types in the NISMO suspension. The stock springs are progressive fronts and linear rears. The new NISMO springs are now linear fronts and progressive rears. I think that having the linear spring in front now in which the spring rate never varies changes EVERYTHING in the way the car reacts to various impacts in the road surface. As mentioned by others before, turn-in and steering response is greatly increased with the full suspension, even on the shitty tires I'm running. I honestly don't think I'll feel the full potentional of the car until there's new rubber at all four corners.
I have a nice stretch of road in which I compared the three stages of build-up. It's a long, clear S-turn with a sharp, high-speed, right-hand sweeper at the end. There are no outlets on this road so I can go full-bore without worrying about any cars pulling out from a side street. With stock suspension, 80 MPH through the sweeper was about as comfortable as I felt, as well as the point I'd really start to plow. With only the sways installed, I easily hit 90 MPH and still felt very stable. With the full suspension and shitty tires, mind you, I hit 95 MPH this morning before letting off. With new rubber I feel that 100 MPH is easily attainable. Not that I have to try, but at least I know it's a goal that could be met. With the full suspension, you have to re-train your instinct for steering input. SMOOOOOTH is the word. No longer are you wrestling with the wheel to make minute corrections mid-corner.
Any questions?
Old Dec 5, 2003 | 07:03 PM
SHO-TIME's Avatar
SHO-TIME
I just picked up my car and I love the NISMO S Tuned suspension!!! The guy above has said it well... it's simply amazing! no more fwy bounches... it's stiff but very comfortably stiff. The bouces are so much more crispier and you won't get sea sick from that! This is a MUST HAVE!
I can't wait to take it to the Canyon run tomorrow and tear up the twisties!
Old Dec 5, 2003 | 07:29 PM
jmark's Avatar
jmark
Sounds like the dang bounce is gone! Give us a detail report after you get back from the twisties!
Old Dec 5, 2003 | 07:31 PM
jmark's Avatar
jmark
I have read that report several times. If you read on further down it comes out that the NISMO springs are all progressive and the stock springs are linear.
Old Dec 5, 2003 | 09:09 PM
Gsedan35's Avatar
Gsedan35
Reread the thread
https://my350z.com/forum/showthread....o&pagenumber=1
that picture shown shows the rear springs, NOT the fronts. Nothing is said by the author that changes how he says the front nismo's are Linear and the rears are progressive. The comments I posted were aimed at his saying the STOCK front springs were progressive, the issue of how he says the front nismo springs are linear remains. I had previously heard that all 4 nismo springs were progressive. But hearing a actual owner of the setup say. "The new NISMO springs are now linear fronts and progressive rears. I think that having the linear spring in front now in which the spring rate never varies changes EVERYTHING in the way the car reacts to various impacts in the road surface." Kinda over rides what I was told before that point. I would never argue with someone that actually owns said parts. Of course what we don't have is a picture of the front nismo springs on his car
Old Dec 6, 2003 | 12:34 AM
fairladyZ in Japan's Avatar
fairladyZ in Japan
I have had the S-tune since April, 2003... and I love it. The suspension setup eliminated the "bounce", the handling improved significantly, and it has improved the overall fun of pushing the Z to its limit.
At the time of installing the S-tune...I also bought the TE37's and S03's... in 19" configuration.
There has been no feathering to date after driving over 5,000 miles.
