Stock Upgrade or Brembo?
Old May 7, 2011 | 11:26 AM
djwatts's Avatar
djwatts
Default Stock Upgrade or Brembo?
So this is my dilemma, I currently have an 07 base 350z with stock pads, rotors at 55k. I can get a great deal for a oem brembo kit (rotors, pads, lines, F&R) of an 03 track, question is would I be better off upgrading my current setup to slotted rotors, ss lines, hawk hp plus pads, and motul brake fluid or pull the trigger and get the brembos?
Cliff Notes:
Normal street use
1-2 Track days a year
Not FI
Old May 7, 2011 | 01:36 PM
thekinn's Avatar
thekinn
as you get better on the track, the small brakes are likely to start fading. Brembos will help, but aren't heat proof. Rotors/pads are going to be more expensive on the Brembos too - not much, but more.
So.. it depends on what 'better off' means.. Bigger, better looking, yes. Necessary for your driving? only you know that - how are your current brakes performing? What's your budget like?
Old May 7, 2011 | 02:47 PM
djwatts's Avatar
djwatts
Currently my stock brakes are doing good they brake when I need them to indoor heavy braking, only downside is screeching when they get used up a bit, but then again I haven't been on a brembo equipped car. Budget wise, the brembos are coming in for a good deal if I pull the trigger, later on just upgrade the rotors and pads
Old May 7, 2011 | 03:26 PM
These are trivial.
Old May 7, 2011 | 06:01 PM
djwatts's Avatar
djwatts
Any recommendations?
Old May 7, 2011 | 06:09 PM
350z_Gio's Avatar
350z_Gio
I would just go with the brembos especially since you say you can get them for a good price. If you start tracking the car more the brembo will obviously be more fade resistant with the proper pads and fluid. I mean it's all on what you want to do. IMO I wouldn't waste money on the stock brakes.
Old May 7, 2011 | 06:12 PM
djwatts's Avatar
djwatts
Thats probably what I'll end up doing is getting the brembos, thanks for the opinions
Old May 7, 2011 | 06:26 PM
Nick Mystic's Avatar
Nick Mystic
I have the brembos on my "06 Grand Touring model. I just finished reading a couple of books about Z cars and they talked about the stock brakes vs. the brembo brakes. Basically, they said both brakes stop you equally well, but the brembo's are much more resistant to fading if you do repeated hard stops. I don't do any track days, and I don't drive hard on the streets, so I can't speak from any first hand knowledge.
Attached Thumbnails Stock Upgrade or Brembo?-img_0161.jpg   Stock Upgrade or Brembo?-img_0243.jpg   Stock Upgrade or Brembo?-img_0240.jpg   Stock Upgrade or Brembo?-img_0157a.jpg
Old May 7, 2011 | 06:40 PM
djwatts's Avatar
djwatts
If I'm wrong please correct me, an 07 and the 03 brembo brakes are the same caliper wise correct? The only difference would be pistons ? Brembo 4 up front and 2 in the rear Vs. My base model 2 up front and 1 in the rear?
Old May 8, 2011 | 04:00 AM
thekinn's Avatar
thekinn
No. the fronts change at year 2006.
Rotors are larger with the Brembo setup too (you made mention of upgrading rotors and pads later with the Brembo setup). If you go Brembos, you will need all new rotors, pads and lines.
Old May 8, 2011 | 05:17 AM
tally350z's Avatar
tally350z
I was in the same situation. I decided to go ahead and get the Brembo's and I love them. Glad I got them.
Old May 8, 2011 | 06:38 AM
djwatts's Avatar
djwatts
When you got the brembos how long after did you have to go ahead and replace the rotors? The ones I'll be getting are coming off an 03 track with 65k on them.
Old May 8, 2011 | 07:45 AM
acke15's Avatar
acke15
just do it all at once, and search the classifieds on here for rotors and pads. i set was sold on here for 500$ bnib of stoptech rotors and pads..
Old May 8, 2011 | 08:20 AM
terrasmak's Avatar
The Brembo rotors are also much wider, so they can handle heat better.
Old May 8, 2011 | 08:22 AM
djwatts's Avatar
djwatts
From the information gathered, I'm going to jump on this deal and see the turnout once installed, thanks everyone.
Old May 8, 2011 | 06:54 PM
sry110's Avatar
sry110
Good thread. I just bought a set of used brembo calipers off a 2007 Z and I'm putting them on my 2006, along with brand new rotors. I'm hoping a notice some better performance out of the Brembo setup relative to the OEM '06 brakes, but if not at least I'll have something that looks real nice!
Old May 8, 2011 | 08:32 PM
djwatts's Avatar
djwatts
Let me know how it turns out man, take some pictures of the install as well. I'll post up when I get mine
Old May 8, 2011 | 10:08 PM
terrasmak's Avatar
You will not notice anything unless you run on the roadcourse.
Old May 9, 2011 | 09:43 AM
sry110's Avatar
sry110
That's what I was thinking. Thanks for the confirmation!
Old May 9, 2011 | 09:44 AM
sry110's Avatar
sry110
Will do. I'm scheduled to go in May 19th for the swap so I'll try to post up some impressions that night.
