Drop spring set up question???
Old May 13, 2011 | 02:21 AM
nismo4life11's Avatar
nismo4life11
Default Drop spring set up question???
Hey guys just ordered Vogtland drop springs 1" drop all the way around and I'm running some Miro 359 19x8.5 +15 and 19x9.5 +20 on stretched tire. Now my question is am I going to need a front and rear camber kit and the rear toe adjustment? Or do I not need them at all I know that there are a thousand threads on this but im looking for a definitive answer yes no this or that are needed for a 1" drop. Also Id really like to see some pics of some 350's with these springs too.
Old May 13, 2011 | 08:34 AM
terrasmak's Avatar
If you searched, you would have learned that no 2 cars are the same. Till you install the springs, you will not know if you need a camber kit. The rule of thumb is, Yes you will need a rear kit, the front will be out of spec for camber but most of us live with the extra front camber, as aggressive drivers need the extra front camber.
davidm350
Oct 31, 2015 02:28 PM
A_MEISTER
Suspension
Oct 25, 2015 04:50 PM
Paul.
Oct 16, 2015 07:34 PM
CJs_Z33
Sep 18, 2015 12:06 PM
