G35 h techs
Old May 19, 2011 | 06:11 AM
RodgePodge's Avatar
RodgePodge
Default G35 h techs
I got some G35 h techs for free from a friend and I'm curious to know if they'll work on my ZR. What are y'alls thoughts?
Thanks in advance.
Old May 19, 2011 | 07:15 PM
RodgePodge's Avatar
RodgePodge
Will the car look right when it settles?
Old May 21, 2011 | 09:45 AM
Gsedan35's Avatar
Gsedan35
Thoughts? Yes, I'll get right to the point.
Resell them and get something worthwhile.
Tein H-tech G35 coupe .6“/.3“(fronts are progressive, rears are linear)
Spring rates in lbs 324/260 (final rates only, softer intial front progressive rate unknown)
The problem is when installed on your ZR, you won't end up with the drop they would give on the G35 coupe. You'll end up with -.1" front and +.2" rear. not to mention that the rear springs are way too soft vs your oem springs.
350ZR oem spring rates
314/427
Here's a list of aftermarket springs
Eibach 350Z Pro-Kit progressive springs 1”/1”
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
Eibach 350Z Sportline progressive springs 1.2"/1.2"
F: 239/400 R: 257/435
RSR 350Z linear springs .6”/.6”
Spring rates in LBS 345/417
Hotchkis 350Z Linear springs .6”/.8”
Spring rates in lbs 340/330
Tein S-tech 350Z springs .7“.6“ (fronts are slightly progressive, rears are linear)
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
Tein H-tech 350z linear springs .3”/.2”
Spring rates in LBS 358/375
Progress Technology progressive springs 1.0”/1.0”
Spring rates in LBS 425/385 (final rates only, softer intial front progressive rate unknown)
Tokico D-spec shock & spring package
350Z - DSK512 - 375f/375r - Linear Springs 1"/1.5"
Tanabe GF210 Series 350Z progressive springs 1”/1.2”
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown) IMO, I'd pick Eibach Pro-kit over this spring.
Tanabe NF210 Series 350Z progressive springs 1.2”/1.2” higher
Spring rates in LBS 314/353
Oem spring stiffness on a 1.2” drop, not a choice I would make
Skunk2 350Z progressive springs 1.3”/1”
Spring rate in LBS 238/381 237/395
Swift 350Z linear springs .8”/.6” drop on 350Z,
Spring rates in LBS 336/364
Swift 350Z Spec-R progressive springs 1.2”/1”
Spring rates in LBS intial/final Front: 291/392 Rear: 280/448
Vogtland 350z progressive springs 1”/1”
Spring rates in LBS initial/final front 257/354 initial/final rear 285/422
Kg/mm springs 350Z DR21 super sport 15mm drop
Spring rates in lbs initial/final front 246/398 initial/final rear 252/409
Kg/mm DRacing progressive springs 1.2”/1.2”
Spring rates in LBS initial/final front 252/454 initial/final rear 252/482 rear
Espelir 350Z progressive springs 10mm drop F&R
386/515 (softer initial progressive rates are unknown)
Most often purchased by owners chasing spring rate specs. But this spring is also often resold when they fail to deliver on the promise those specs were supposed to delivery. Not a bid surprise, they are progressive, not linear.
H&R sport progressive springs 350Z 1.3”/1” drop
Spring rates in LBS 370/400 (peak rates only, softer initial rates are unknown)
Old May 21, 2011 | 10:12 AM
huyrua's Avatar
huyrua
Gsedan35 knows his infos when it come to G/Z suspension.
JjL
East Canada
Jun 12, 2019 03:04 AM
seagrasser
Oct 11, 2015 03:27 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
