Anyone done bleeding power steering?
Old May 20, 2011 | 06:34 AM
2fasst's Avatar
2fasst
Default Anyone done bleeding power steering?
The manual stated to turn OFF engine, then turn steering wheel lock-to-lock left and right.
This is really hard to do and it seem to put a lot of stress on the steering column. Remember, with the engine off, the is no hydraulic assist at the steering rack, so all the steering/turning must be done via the steering column.
I'm concerned that the torsion bar and flex couplings inside the steering column could get damaged.
Attached below the the factory service manual. I've seen mis-prints before?
What are your thoughts? Any ASE mechanics in here?
Old May 20, 2011 | 06:50 AM
350z 6spd's Avatar
350z 6spd
Do what it says...I usually do it with the engine on and it hasn't been an issue but don't blame me if you break something.
Old May 20, 2011 | 06:58 AM
KornerCarver's Avatar
KornerCarver
You do know that cars used to come without power steering. Turning the wheels didn't hurt the steering column then and it won't hurt it now.
Old May 20, 2011 | 07:15 AM
2fasst's Avatar
2fasst
well not entirely true Cars with no power steering assist were designed that way in mind. The steering column has no torsion bar, which activates the hydraulic solenoid for left or right. I'm sure the couplings are probably beefier as well. And finally the steering ratio is probably more truck-like, making it easier to turn, but more revolutions for each steering angle increased.
Old May 20, 2011 | 07:41 AM
laze1's Avatar
laze1
Park the car in the grass/dirt if you are concerned with the stress of this method...or raise the front wheels off the ground and do it...
Old May 20, 2011 | 07:45 AM
2fasst's Avatar
2fasst
I actually put it on an alignment rack with front wheels on turn plates. But I made this post because my partner insist that the front wheels be on the ground to be properly done.
Old May 20, 2011 | 05:52 PM
halfrice's Avatar
halfrice
done mine twice up the air now
Old May 20, 2011 | 10:21 PM
2fasst's Avatar
2fasst
I'm sorry, you did yours twice with wheels up in the air?
Old May 21, 2011 | 11:19 AM
gregom's Avatar
gregom
I did mine with front wheels off the ground, worked great, no problems.
Old May 21, 2011 | 01:00 PM
str8dum1's Avatar
str8dum1
why not just drive the car and fill it as it goes down? you are making a big deal out of nothing.
Old May 21, 2011 | 02:25 PM
raycs7's Avatar
raycs7
Remember do not use regular power steering fluid..
lapham3
Oct 7, 2022 03:15 PM
Depravity
Oct 1, 2015 04:49 PM
