springs vs. coilovers... opinions appreciated
Old Jun 5, 2011 | 06:25 PM
jdmfastdc2's Avatar
jdmfastdc2
Default springs vs. coilovers... opinions appreciated
i have a 2007 350z that i recently purchased. i would like to lower it just a bit, maybe 3/4" - 1" front and rear. I dont plan on road racing it, its mainly just a daily driver. So i was looking into tein s-techs, but from what i read most people say its smarter just to spend the extra money and go for full coils. is it really necessary for my needs? i suppose if i did id just go with tein basics or d2 racing coils. opinions please!
Old Jun 5, 2011 | 06:30 PM
terrasmak's Avatar
The both have advantages, the shocks you get with cheap coilovers suck, but you can adjust you drop.
Old Jun 5, 2011 | 06:32 PM
03threefiftyz's Avatar
03threefiftyz
Review these two threads. You can then make an informed decision for what will work best for you.
https://my350z.com/forum/brakes-and-...ion-101-a.html
https://my350z.com/forum/brakes-and-...ic-thread.html
Old Jun 5, 2011 | 06:33 PM
jdmfastdc2's Avatar
jdmfastdc2
will the shocks i get with tein basics, megan, or d2 racing coils suck? i doubt ill really adjust my ride height at all. id probably set it to just under an inch and leave it, that's why im wondering why im being told just to spend the extra money. if i did tein s-techs would i notice the drop? is there really any reason at all not to just buy springs
Old Jun 5, 2011 | 06:35 PM
AznSky's Avatar
AznSky
+1 on coilovers. I got s-techs and matched them with koni yellows. The performance is good but now I want to go lower I can't. If it's just a daily then go for some budget coilovers
03threefiftyz
Yes, the shocks will suck with those coil-overs. If you just want a specific drop, buy springs and be done with it.
Old Jun 5, 2011 | 06:38 PM
jdmfastdc2's Avatar
jdmfastdc2
ya i think thats probably best. i was comparing eibach pro-kit and tein s-tech. the eibachs are more but have a little bit bigger drop, but i really want to make sure i avoide camber and tire wear issues. Looks-wise is there much of a difference. Can you tell a Z with tein s-techs is lowered if you didnt know better?
Old Jun 5, 2011 | 06:49 PM
350Speed's Avatar
350Speed
I have the S-Tech on mine with the rear spring mount mod. The car is lowered with not camber issue. Still have the oem shocks.
350ZTheStandard's Avatar
350ZTheStandard
Thanks for pointing the new member to the numerous threadS on the same topic & the search function. I am sure I probably asked the same question 4 years ago myself.
Old Jun 5, 2011 | 08:18 PM
SE5spd's Avatar
SE5spd
Get sportlines if you wanna be on a real budget. Pretty low and only $200ish
Old Jun 6, 2011 | 01:58 AM
Gumby Gone Wild's Avatar
Gumby Gone Wild
^probably gonna need a camber kit with the sportlines, and depending on how hard/often you drive you'll be replacing your shocks fairly soon. I'm by no means a suspension expert though, in fact probably the farthest thing from it so definitely do your research!
I vote get the springs you want and if you don't like something about them upgrade to coilovers later.
Old Jun 6, 2011 | 08:16 AM
TehkMob's Avatar
TehkMob
If you NEVER plan on "slamming" your Z then springs all the way. Get tanabe gf210 springs, They ride just a slight bit stiffer than stock and drop is like 1.2 er sumthing. Coils are a waste of money if you never plan to slam your car. Plus you can stick with stock shocks. Springs all the way IMO. I'm on coils and it sux for daily.
Old Jun 6, 2011 | 08:30 AM
terrasmak's Avatar
I love my coils, the ride OK even with 700 pound springs, but they are way out of most peoples range. All my solid bushings suck for daily driving.
BTW stock shocks do not last long, average is 60k with stock springs, then they wear much faster once a lowering spring is installed. Unless you have a low mile car, get a set of shock when you install the springs. D Specs can be had for $500 and are much better quality dampers (give you a great ride) than any cheap (BC, Stance, Megan , Ksport ) Coilover.
Old Jun 6, 2011 | 10:25 AM
TehkMob's Avatar
TehkMob
Yeah but if your going to replace the shocks midas well buy a full sleeve setup. Spring dont do **** to shocks the amout of travel from stock to lowering spring is minimal. Most lowering springs will still be preloaded on the front. If you go springs you wont need shocks unless like said before, you have a high mileage car. Ksport offers a fullsleeve thats fairly priced with good quality. Really in the end it all depends on you!
Old Jun 6, 2011 | 12:02 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
A lowering spring absolutely compromises the life of a shock. There are no ifs ands or buts about it. Sleeves do nothing to alleviate preload, only a coilover that allows adjustment of spring length independant of the mounting bracket will allow control over preload (or using a shorter than desired spring in the first place, which then likely will be mismatched to the stroke of the shock).
To the OP, you have to establish for yourself your
1. budget
2. realistic intended uses
and then compare the prices of what you're buying. Just because a coilover is close in price to a set of springs/struts, doesn't mean a coilover is a 'better buy'. If your coilover choices are D2 or Tein Basics, you would be far better served with the D spec shock and spring setup, for less money than either of those coilover choices, and you'll have a far superior product. This setup works better because their strut and spring were designed around one another, so the stroke of each is more closely matched as compared to a random brand lowering spring on a stock strut
Old Jun 6, 2011 | 12:37 PM
zerosec's Avatar
zerosec
if u can afford a good set of coilovers i wouldn't think twice ( Bilstein, KW...)
if its just a matter of look just do the springs, but i strongly recommend going the other way
Old Jun 6, 2011 | 02:44 PM
TehkMob's Avatar
TehkMob
Lowering springs dont do **** to stock shocks... The lowering sprigs end up being preloaded before they ever go on the car!! Do you know what preload is? Means there is already compression on the spring before ANY weight is put on it by the car. You have to compress the lowering spring before you can even put them on! how does that affect the shock? A stock shock still has like 3000 inches of suspension travel plus most lowering spring come with a stiffer spring than stock.. You will NEVER hit bumpstop on a stock shock with a good lowering spring period. You can rock lowering spring on a stock shock on a 350 all fuggin day with out problems unless your shocks already have the miles... One thing he did say that was right, 1. be realistic with the goals you have for your car and 2. budget.
Old Jun 6, 2011 | 02:48 PM
sry110's Avatar
sry110
I'm kind of in this same boat. Looking to go a bit lower than my current Hotchkis+OEM shock setup, but want forgiving ride quality while minimizing body roll and front to back pitch. I dont know exactly where I want my ride height to be and I have a somewhat steep driveway to contend with, so I'm looking at coilovers to give me height adjustability as needed (even though I'll probably set them once and forget it). I'm realizing that it's probably going to take an expensive setup (Bilstein, KW, etc.) to get the end result I want. Gotta pay to play I suppose!
BUT, if you know what drop you want definitively, you can shop springs and upgraded shops and save yourself a buttload of money.
Old Jun 6, 2011 | 03:05 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Coilovers are great of want to be able to corner balance a car for track days, slam it for that Hella Flush look or just like to ride low. But with entry level coilover you tend to get a harsher ride.
If you NEVER plan to lower the car any lower than 1" and looking for a smooth ride then you may want to look at Eibach Pro Kit. They provide an excelent ride. We also have them on sale right now for $269.37
Depending on how many miles are on your car you may want to upgrade your shocks as well.
Be sure to check out our inventory http://www.vividracing.com/catalog/s...san_350Z_03_08
Old Jun 7, 2011 | 05:16 AM
05Z33's Avatar
05Z33
I was in the same boat as you. I wanted springs, but knew that I would have to upgrade the shocks eventually. That's why I decided on saving a few more hundred bucks and got the BC coilovers. You can adjust the the height if you want to go lower later on, and you can adjust the how stiff or soft you want your ride.
