Ichiba A-arm question
Old Jun 9, 2011 | 07:33 AM
350Speed's Avatar
350Speed
Default Ichiba A-arm question
Hi everyone,
I ran across the thread on G35 forum, people was saying that Ichiba a-arm doesn't give positive camber. It only gives more negative camber. Is this true or not?
Thanks in advance.
Old Jun 9, 2011 | 07:55 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
http://z1auto.com/prodmore.asp?model...ng&prodid=3993
minimal positive adjustment compared to other arms.
Old Jun 9, 2011 | 11:15 AM
Jun's Avatar
Jun
Does this mean if my car is lowered, which gives it negative camber like this /-----\, this a-arm will be able to adjust it and correct it to |------| ?
Old Jun 10, 2011 | 06:27 AM
Jun's Avatar
Jun
Their website mentions +/-3 degrees though?
http://www.ichibausa.com/ic35g35caarm.html
Introducing the Ichiba front and rear adjustable camber arms for your 350Z and G35. Ichiba front and rear adjustable camber arms are direct replacements and allow you to adjust camber on the front and the rear of your 350Z or G35. These arms uses a special compound rubber bushing to ensure smooth operation and minimize noise. No more premature tire wear on your expensive set of wheels! And better handling too!
Appox Adjust: +/- 3 Degree (Depend on how low the car lowered)
Note
The camber arm will not adjust camber to 0 degrees due to car lowered and original factory setup data.
Application
G35 2DR 03-07
G35 4DR 03-06
350Z 03-08
Old Jun 10, 2011 | 06:40 AM
Z1 Performance
Former Sponsor
thats probably an accurate measurement for the rear kit; what is on our site is correct
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
