Leaking brake fluid
Old Jun 11, 2011 | 07:30 PM
Aust350z's Avatar
Aust350z
Default Leaking brake fluid
I had Brembos installed last week and have noticed I'm leaking brake fluid.
The master cylinder is almost at min and the other small chamber under the brake fluid lid is empty.
I'll be taking the the car back first thing on Monday.
In the meantime I've picked up some more brake fluid. Is it safe to open the master cylinder and top up the fluid?
Old Jun 11, 2011 | 07:43 PM
omsin523's Avatar
omsin523
yeah it should be fine, thats how your suppose to pour in brake fluid
Old Jun 11, 2011 | 08:06 PM
chrisjersey06's Avatar
chrisjersey06
Use your air brakes in the mean time.
Old Jun 11, 2011 | 09:05 PM
Aust350z's Avatar
Aust350z
Yup fixed my window motors so the hands are getting a work out.
Old Jun 11, 2011 | 09:08 PM
winchman's Avatar
winchman
"The other small chamber" is the clutch reservoir.
Old Jun 11, 2011 | 09:40 PM
Aust350z's Avatar
Aust350z
Doesn't sound like that should be empty as well?
Old Jun 12, 2011 | 12:41 AM
Yes if you have the proper protective equipment.
Old Jun 12, 2011 | 01:26 AM
Aust350z's Avatar
Aust350z
Bugga. Lent my mate my gas mask! Will get the tow truck to take it instead.
Any advice re empty clutch reservoir?
Old Jun 12, 2011 | 03:41 AM
Lightbulb
Yes. Check section CL-6 of your service manual for "bleeding" instructions.
Old Jun 12, 2011 | 10:34 AM
winchman's Avatar
winchman
I'd just add fluid first. Don't bleed it unless it's not working properly.
The clutch system is entirely separate from the brake system. The reservoirs are side by side only because the pedals are right next to each other.
derekinthez
South East
Sep 28, 2015 06:35 PM
