Eibach Pro Kit Springs
Old Jun 21, 2011 | 08:05 AM
08ZnUAE's Avatar
08ZnUAE
Default Eibach Pro Kit Springs
OK I've searched this forum and can't find the answer I'm looking for so here is my question
I am wanting to put Eibach Pro Kit Springs on to lower my car a little bit because it is a daily driver and still want a streetable ride. Will the stock suspension adjustments allow for the corrections needed after the spring installation and only lowering it about 1"?
Thanks in advance for any feedback be it good or bad.
Old Jun 21, 2011 | 08:27 AM
arsey51's Avatar
arsey51
Which stock suspension adjustments are you referring to ? The answers your looking for are in the braking/suspension forum. Search again.........
Old Jun 21, 2011 | 10:02 AM
terrasmak's Avatar
Luck of the draw if you need a rear camber kit. Most cars will need a rear kit if you go more than 3/4 inch drop. The front will be fine if you don't mind your camber at -1.5ish.
EnjukuRacing
Sep 30, 2015 06:55 AM
