Stoptech Trophy BBK for Z33, Z34, and others
Old Jul 11, 2011 | 02:16 PM
Blu_Blur's Avatar
Blu_Blur
Originally Posted by StopTechErik
Our 2 piston rear kit starts at $2295, a little more expensive due to the deep hat which accommodates the factory drum style parking brake. There's a lot of machine time and material waste to make them which leads to some added costs.
Is there any noticebale difference in stopping between the 332 and 355 mm brakes?
Old Jul 11, 2011 | 02:36 PM
gabe3d's Avatar
gabe3d
Looks like ther is some confusion in here. I'm pretty sure that the 2195 and 2295 prices are for the regular non Trophy Kit, correct Erik?
Old Jul 12, 2011 | 06:50 AM
StopTechErik's Avatar
StopTechErik
Vendor - Former Vendor
$2195 front and $2295 rear are the starting prices of the kits and would be the standard red or black calipers with slotted rotors. Sport Trophy kits add $750 to the starting prices of our kits and any kit can we make can be ordered with the Trophy option.
As far as single stop performance, the 332 and 355mm kits be the same, however under heavy or repeated use the 355mm kit will have the advantage as its greater heat capacity will keep the system from going into fade.
The chart at the bottom of this page shows similar stopping distances but noticeable temperature differences as the system gets larger:
http://www.zeckhausen.com/testing_brakes.htm
Old Jul 12, 2011 | 07:59 AM
Blu_Blur's Avatar
Blu_Blur
Thanks Erik. What is the 'Trophy' kit and what are the benefits?
Old Jul 12, 2011 | 10:48 AM
StopTechErik
The Trophy Kit benefit is primarily reduced weight, about 20% less weight per caliper than the standard parts. The anodized finishes on the hats and caliper have no pigment so they won't discolor at high temperature and there's of course the exclusivity of having something other than the more typical red or black painted calipers.
Old Jul 12, 2011 | 10:43 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Yet nobody has answered my question.
Can you buy the calipers separately if you already have a stoptech BBK?
Old Jul 13, 2011 | 07:47 AM
Blu_Blur's Avatar
Blu_Blur
I believe that when it comes to brake parts, yes you can buy calipers from another manufacture and add them to another manufacturers rotors, lines, pads etc.
A guy I met at a recetn Z meet is suggesting I go the peice-meal route in order to save money but still have great stopping capability.
Old Jul 13, 2011 | 10:33 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
1 piece rotors are a way to save some cash, but if you're going to be seriously tracking the car you might want to think about the benefits of a 2 piece.
As far as mixing and matching, that's a gray area. Yes you can do it, but you'll spend a lot of time figuring out what will and won't fit.
Old Jul 13, 2011 | 11:00 AM
Blu_Blur's Avatar
Blu_Blur
Yeah, with one-piece rotors, if they ever get warped or need to be resurfaced (not sure if slotted rotors can be resurfaced), I might need to get rid of the whole rotor, right?
Old Jul 15, 2011 | 02:32 PM
Vivid Racing
Vivid Racing
Slotted rotors can be turned, but a lot of shops will tell you they can't. If you have trouble finding a shop to do it local to you, find a machinist. A machine shop can take care of it for sure.
As far as the 1 pc rotors warping is concerned, most of the time when someone claims they've got a warped rotor, it's actually just uneven pad deposits on the rotor. Rotors do warp, but it doesn't cause the pulsating pedal most people claim it does.
Old Jul 15, 2011 | 02:36 PM
Vivid Racing
Vivid Racing
Erik answered you
The front brackets that relocate the calipers for reduced knockback are available separately but they do require new front brake lines as well.
As far as more affordable kits are concerned, our 4 piston 332mm front only kits start at $2195
Is that $2195 for just the calipers? Or the entire kit?
Do you offer just the calipers?
$2195 is for the front kit, calipers, brackets, lines pads, rotors and hardware.
Replacement calipers are sold separately if needed.
By the way, thanks for the help Erik!
Old Jul 15, 2011 | 03:36 PM
Waiz's Avatar
Waiz
Originally Posted by vo7848
Old Jul 15, 2011 | 11:25 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
ah yes, missed that one.
my bad!
Old Jul 18, 2011 | 03:57 PM
Vivid Racing
Vivid Racing
my bad!
How dare you miss a post!
Old Jul 18, 2011 | 10:21 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
I know, I know.
May i be struck down for all my sins!
Old Jul 19, 2011 | 08:18 AM
Vivid Racing
Vivid Racing
Show the world you're a baller with a Stoptech BBK from Vivid Racing!
sales@czp
Sep 23, 2019 03:30 PM
