SS brake line failure (Pic)
Old Jul 7, 2011 | 02:40 PM
steve774's Avatar
steve774
Default SS brake line failure (Pic)
I suddenly lost all my brake pressure while I was doing a lapping event yesterday. I was able to safely get off the track and discovered a huge leak from my Stoptech SS brake lines near one of the connectors.
Has anyone else ever encountered this? What could have caused this line to fail like this? I bought a set of used OEM Brembo calipers and these brake lines came with the set so I don't know the history behind them. I had them on for a few months and were working fine until I hit the track.
I attached pics of the brake line. I pulled back the black plastic to show the leak spot just for the pic. The lines were not exposed when they were installed.
I am getting new Goodridge brake lines this weekend.
Attached Thumbnails SS brake line failure (Pic)-img_0499.jpg   SS brake line failure (Pic)-img_0500.jpg
Old Jul 7, 2011 | 02:44 PM
BornSlippyZ's Avatar
BornSlippyZ
Looks like an over crimped fitting....Good to hear you and your Z are ok.
Old Jul 7, 2011 | 02:48 PM
bimmertech's Avatar
bimmertech
they were most likely incorrectly routed, or had an excessive amount of tension placed on them while performing other maintenance.
it is possible too that they had a defect, but in my experiences it is generally a user error.
Old Jul 7, 2011 | 02:58 PM
lgear080's Avatar
lgear080
I got a blown line from Coz awhile back. It was brand new, blown in a similar
fashion (though rec'd from the manufacturer that way).
It was summarily replaced quickly with no grief.
This happens as nothing is invulnerable to breakage.
Old Jul 7, 2011 | 09:53 PM
winchman's Avatar
winchman
That looks like it had some serious abuse to bend the fitting where the line goes into the nut.
Old Jul 11, 2011 | 04:07 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
You should send them to stoptech so they can do a failure analysis on them. Why keep them and speculate?
