Is it okay to put Nismo springs on stock suspension. And will the spring rates be comfortable? I've looked all over and no one has given a straight answer. Im looking to drop it .08 but is the whole kit necessary for actually lowering the car and improving performance? thank you!
They are red, so I assume that they're the S TUNE, does that sound right.?
from the S Tune kit:
I dont think you're going to find much, if any feedback on mixing these springs with any other struts, because they were sold as a set. The rates are 454 lbs up front and 498 lbs rear (not sure if that rear rate is peak or start, as it's progressively wound)
If it's from a 350Z NISMO Edition, those springs are 492 front/336-672 rear
