Has my 08 been lowered?
Old Aug 25, 2011 | 01:12 PM
ronn1's Avatar
ronn1
Default Has my 08 been lowered?
Just got this car and have no cars to compare at this time.
I'll post pics later, but I get TWO FINGER GAP (tight) up front and 3 fingers (TIGHT) in the rear. The tires and wheels are STOCK. I looked at shocks and springs...they don't *look* like they have been swaped out (37 k Mi on car)..but I can't say for sure. Appreciate any input until pics are posted.
Old Aug 25, 2011 | 01:24 PM
Waiz's Avatar
Waiz
Post pics of your Z's exterior on a level ground as well as the shocks/springs for us to confirm, fingers are an unrelaible resource.
Old Aug 25, 2011 | 01:31 PM
Junkster's Avatar
Junkster
Best way to tell is to look at the shocks and springs...
Varying tire thicknesses/sizes can change your ride height...
Old Aug 25, 2011 | 01:35 PM
drivessidewayz's Avatar
drivessidewayz
^^ What he said.
Old Aug 25, 2011 | 01:38 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
VVV
Attached Thumbnails Has my 08 been lowered?-600px-350z_rear_suspension_service_specifications.jpg
Old Aug 25, 2011 | 02:03 PM
ronn1's Avatar
ronn1
Originally Posted by AdvanZ33
VVV
Now that will help. Need to get it on level ground but I'm getting 26.25" up front vs 26.9" in the specs..so I'm .6" lower up front. The rears look stock Ht...maybe a tad lower.
I would assume I'm stock suspension, since there are only 1..maybe 2..aftermarket springs that only lower the car .2"-.3" and those are Tiens. If they were gonna be on lowering springs the next level would be thr RSRs at .6" lower close to my set up on the front. BTW, these springs are not colored (like most aftermarket)..they're BLACK.
Edited..I'm 26.25" up front not 26.75"
Old Aug 25, 2011 | 02:09 PM
AdvanZ33's Avatar
AdvanZ33
What size tires? Are the measurements the same on both sides of the car?
Old Aug 25, 2011 | 02:32 PM
ronn1's Avatar
ronn1
Stock tires (Potenza 18") and rims. Measurements are very close on both sides.
Old Aug 25, 2011 | 02:42 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
VVV
That's also an unreliable way to measure ride height. Different tire and wheel sizes, ground not being level, worn suspension components, etc will affect that measurement. The best way to measure ride height is from the center of the wheel to the fender.
Old Aug 25, 2011 | 03:29 PM
ronn1's Avatar
ronn1
Yes I'm aware of that. Do you have that measurement?
Old Aug 25, 2011 | 03:39 PM
Vivid Racing
Vivid Racing
Not for a stock car, unfortunately. The only Z's I have available are all lowered. When you've got 15 minutes to spare, jack the car up and remove one of the rear wheels. Snap a picture of that, and we'll be able to tell you whether it's lowered or not.
Or maybe you can cruise over to a local Nissan lot and compare your car next to a stock Z?
Old Aug 25, 2011 | 05:52 PM
AdvanZ33's Avatar
AdvanZ33
So assuming you have a coupe, you are on 225/45 245/45 stock tires and we use the FSM diagram for ***** and giggles; then yes, you are lower than stock. Most aftermarket springs are not black, take a rag to your springs and see if there are any legible markings. At any rate, you aren't much lower than stock so where do you go from here?
Old Aug 25, 2011 | 06:56 PM
ronn1's Avatar
ronn1
I just put up pics..looks odd with the flash lighting, since gap seems exaggerated. Fronts are lower for sure..ya don't get a tight 2 fingers there stock. Rears look stock height.
Went I replace the shocks with D specs, I'll prolly put on the rsr *Down* springs for a .6" drop..they have rates very close to stock 04.5 revision.
Old Aug 25, 2011 | 07:04 PM
ronn1's Avatar
ronn1
Here are some pics...maybe some of you can chime in. The flash really makes the gap look exaggerated....so don't be *fooled* by that artifact.
FRONT
REAR
SIDE SHOT
FRONT SHOCK/SPRING
REAR SHOCK/SPRING
Old Aug 25, 2011 | 07:11 PM
xX Lil Oly Xx's Avatar
xX Lil Oly Xx
They are stock and you are parking to close to the curb!
Old Aug 25, 2011 | 07:28 PM
ronn1's Avatar
ronn1
That's the parking *stop* block in the parking lot and my front clears it as long as I don't pull up too far.
Old Aug 25, 2011 | 07:34 PM
Bmurray350z's Avatar
Bmurray350z
no. not lowered, at all.
Old Aug 25, 2011 | 09:33 PM
Waiz's Avatar
Waiz
Thanks for posting the photos, you are in fact nose-bleed-high-bone-stock
Nice color Z!
Old Aug 25, 2011 | 10:41 PM
ronn1's Avatar
ronn1
Nice color Z!
Flash pics can be deceptive...I agree it's stock though.
Old Aug 26, 2011 | 07:37 AM
F34RL355's Avatar
F34RL355
raised if anything :P
