Nismo S tune shock question
Old Aug 27, 2011 | 01:29 PM
ronn1's Avatar
ronn1
Default Nismo S tune shock question
First..don't ask me to search. I fully understand the search function and use it all the time. I used it for the question I'm about to ask and came up with very little. So here it goes...can anyone hear tell me what the *comfort* level is with the s tune..vs stock (revised 04.5)? I have a stock 08 and would like a modest drop with tighter handling. Yes...I'm looking at D Specs with RSR or Tien S Techs as well. Just want to know more about Nismo S Tune comfort level since it's non adjutable and you're married to it once they're on.
TIA..
Old Aug 27, 2011 | 02:48 PM
350zfan1's Avatar
350zfan1
TIA..
Have the nismo S tune shocks paired with the eibach pro kit. Decent 1in drop with noticeable handling improvement with very easy ride and still way more responsive than my original track suspension.
Old Aug 27, 2011 | 03:39 PM
ronn1's Avatar
ronn1
Thanks for the response...then that brings up the question...Did you have an opportunity to use those shocks with the original springs intended for them?
..you can't buy the shocks separately.
BTW, I really prefer a small drop on this car..it's already pretty low stock.
Old Aug 27, 2011 | 05:41 PM
SE5spd's Avatar
SE5spd
I had tein s spec and D spec
loved them
Old Aug 28, 2011 | 02:05 PM
ronn1's Avatar
ronn1
Default Bilstein makes Nismo S tune shocks?
Found this:
Nismo makes their own springs, dampers are manufactured by Bilstein. THe Nismo S Tune suspension is prett entry level but if all you do is daily driving, itll work out great. If you are looking for something in the next step up with some adjustability, I would look into the Tanabe S0C. A great coilover without too much compromise in drivability.
Old Aug 28, 2011 | 02:23 PM
beezee's Avatar
beezee
Last time I heard, they were made by Tokico. Who knows for sure?. NISMO themselves.
Old Aug 28, 2011 | 02:33 PM
ronn1's Avatar
ronn1
You're prolly right. S tunes are TWIN and Bilstein only makes monotube (as I recall). I know Bilstein made shocks for the Frontier trucks..maybe that's the confusion.
Old Aug 28, 2011 | 02:37 PM
Gsedan35's Avatar
Gsedan35
Incorrect. Like the regular oem shocks, Tokico also makes the Nismo S-tune shocks. In some markets, buyers can purchase a Bilstien sport suspension, which has nothing to do with Nismo.
Bilstine does make some twin tube shocks for certain applications, generally where they are marketing a value price vs a more expensive momo tube version for the same application.
Old Aug 28, 2011 | 02:41 PM
Gsedan35's Avatar
Gsedan35
^ The Bilstein sport suspension would have been a dealer sold kit. Not a factory installed option. And I have only seen it in Japan and europe.
Old Aug 28, 2011 | 02:53 PM
ronn1's Avatar
ronn1
I think the confusion came from the fact that Bilstein did make S tune shocks for the Frontier trucks.
Old Aug 28, 2011 | 09:59 PM
OK I wrote a detailed critique of the Nismo S tune shock but, as you requested, will not tell you to search.
Old Aug 28, 2011 | 10:56 PM
ronn1's Avatar
ronn1
Searching is sometimes a real BEEATCH. I finally found some more info (I think your review) on nismo s tune suspension by searching under (I think) *spring rates tune*...leaving out *nismo*.. *review*. Go figure. Using *NISMO* can be too inclusive and you wind up with a sh$$t load of crap to wade through. Search is a usefull tool and I ALWAYS try to utilize it in order to prevent cluttering and duplicate threads. Having said this, it can be a very frustrating and tedious process...as it was in this particular case.
One good thing that came out of my starting this thread....I found someone who wanted to sell his fairly new Nismo set up at a great price (it wasn't in the classified section). Something that never would have taken place had I not started this thread.
Old Aug 29, 2011 | 11:59 AM
Neimad's Avatar
Neimad
They were built by Unisia Jecs.
Old Aug 29, 2011 | 01:51 PM
ronn1's Avatar
ronn1
Intersesting..found this:
NISSAN, UNISIA JECS DEVELOP SHOCK ABSORBER
Tuesday 26 October 1993 | 00:00 CET
Nissan and Unisia JECS have jointly developed a full-flex shock absorber, automatically iterating damping in two stages. The part will be included in the new Skyline. Under the piston surface valve, the piston compression and retraction speed can be mechanically altered with an iterative sub-valve system. The shock absorber can dampen low and high pitch vibrations. The front shock absorbers are pushed down to 175 to 145 kg, for higher manoeuvrability.
And this:
DAMPING FORCE VARIABLE SHOCK ABSORBER Document Type and Number:Japanese Patent JP05332387
PURPOSE: To improve comfortableness to ride, running stability and a degree of freedom of setting damping force by interposing an adjuster, which opens/closes an extension/ compression common bypass to close one of both extension/compression bypasses and to open the other in accordance with a displacement direction of a flow path, in the halfway of the extension/compression side bypass flow paths, in a damping force variable shock absorber for an automobile suspension device.
CONSTITUTION: For instance, when an adjuster 12 is placed in the first position, a compression side variable throttle R, extension side first variable throttle S, extension side second variable throttle T and an extension/compression common variable throttle U are all opened, to place extension side first flow path D to third flow path F, extension/compression common bypass flow path G, compression side first flow path H to third flow path G all in a circulatable condition. The adjuster 12 in an extension stroke opens the extension/compression common bypass G to open the extension side third flow path F, second flow path E, first flow path D together with increasing a piston speed, to be transferred to a soft range. In a compression stroke, the extension/compression common bypass G is opened, and the compression side second flow path S, first flow path D are opened with the speed and transferred to the soft range. The extension/compression common variable throttle U is closed in the second position.
Old Aug 29, 2011 | 02:34 PM
Waiz's Avatar
Waiz
Old Aug 29, 2011 | 03:24 PM
beezee's Avatar
beezee
Too much info than we need. Good find anyway
Old Aug 29, 2011 | 03:41 PM
ronn1's Avatar
ronn1
You never know where a thread's gonna take you. I think this is pretty good info...we now know these aren't your run of the mill *Tokico* stock replacements.
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
hardkicks
Sep 20, 2015 12:28 PM
CJs_Z33
Sep 18, 2015 12:06 PM
